4oED trans problems..
Old Oct 25, 2007 | 08:23 AM
thehickfarmer's Avatar
thehickfarmer
i just picked up a real sweet 89' f-350 lariat crew cab dually diesel with a 6.9L IDI. Very nice truck!
the trans however has a problem, wont shift automaticlly,you gotta do it by yourself, the guy i baught it from said it was the computer,or some kind of sensor...any other idea? how and where should i start lookin?
Marko
Old Oct 25, 2007 | 10:48 AM
PLC7.3's Avatar
PLC7.3
Do the speedo and tach work flawlessly................ Check fuses, what color is the FIPL/TPS on the IP.... have the truck/trans checked for codes at Azone free...... report back with codes.
Old Oct 25, 2007 | 10:50 AM
thehickfarmer
well..the speedo is jumping all crazy until about 45mph or so..then will go back to normal once passed 45mph, what is the FIPL/TPS?
Marko
Old Oct 25, 2007 | 12:36 PM
David85's Avatar
David85
The E4OD was never offered behind a 6.9L diesel, 1987 was the last year ford used the 6.9. Was the engine swapped?
And are you sure its an E4OD, and not a C6 3 speed?
Old Oct 25, 2007 | 08:27 PM
faststang94's Avatar
faststang94
if its a 89 truck it could have a e40d, and it should have had a 7.3, someone prob just swapped the engine due to cavitiation.
Old Oct 25, 2007 | 11:12 PM
PLC7.3's Avatar
PLC7.3
In both cases it may be just unfamiliarity with the vehicle and components....
Yes it should be an E4OD .. 3 speed plus OD..should have an E on the door post label under trans.
7.3 external identification variance from 6.9 - New fuel filter/fuel heater/water separator, larger/taller cylinder head bolt bosses with ribs.
Cylinder head bolts - 6.9 = 7/16
Cylinder head bolts - 7.3 = 1/2"
Old Oct 26, 2007 | 08:19 AM
thehickfarmer
it is a 1989, it used to have a 460 EFI and was swaped to a 6.9L, it is a E40D,3 speed with an overdrive.
but back to it, i got my speedo jumping like crazy...what can that be?
Marko
Old Oct 26, 2007 | 09:29 AM
starmilt's Avatar
starmilt
do you know if it ever worked right after the swap I dont think the e40d was behind the 6.9s may not have the filps on the pump
Bestays Pom
1983 - 2012 Ranger & B-Series
Jun 14, 2012 08:28 AM
don77
Jan 2, 2009 05:11 PM
notlowyet
Jun 3, 2008 08:29 AM
detmonster
Aug 10, 2002 06:54 AM
