6.9L bell housing adapters for eaton fuller?
Old Oct 23, 2007 | 09:48 PM
thehickfarmer's Avatar
thehickfarmer
just wondering if there are adapters for the bell housing so i could stick a 8 or 9 spd eaton fuller on my truck.
Marko
Old Oct 23, 2007 | 10:46 PM
82F100SWB's Avatar
82F100SWB
Yes, you can do so, I believe you just replace the Ford bellhousing adaptor with one that goes to the SAE pattern you require, then you just use standard SAE stuff from there. Probably the most common app for such a part would be a 6.9/7.3 in a S-Chassis IH truck, and probably the most common of those would be a school bus.
I've never driven one with an 8 or 9 speed, but, I have driven a few 6.9's in S-Trucks backed by 5x2's.
Old Oct 23, 2007 | 11:40 PM
thehickfarmer
what do you mean by "SAE"?
Marko
Old Oct 24, 2007 | 12:34 AM
optikal illushun's Avatar
optikal illushun
that is the bell housing pattern used in the MD/HD truck industry. they come in 3 flavors...its like a spacer that bolts between the engine and transmission.
Old Oct 24, 2007 | 11:22 AM
thehickfarmer
so it is very possible to get an eaton fuller hooked to my IDI?
Marko
Old Oct 24, 2007 | 03:44 PM
optikal illushun
i would say yes, as said above, the IDI was used in medium duty trucks so u just need to locate the right SAE bellhousing...
Old Oct 25, 2007 | 03:16 PM
IHWillys's Avatar
IHWillys
Here's a basic list of what's needed:
- SAE #2 flywheel housing
- Flywheel specific to SAE spec
- Starter specific to SAE spec(note there are atleast two different starter index hole sizes in the flywheel housings)
- Clutch specific to SAE spec(and disc to transmission)
- SAE #2 clutch cover that works with transmission
- Redo trans mounts to SAE style(one on either side of flywheel housing), may require removal/relocation of a crossmember
- I think IH app exhaust manifolds are different from Ford. If so, perhaps it's due to the flywheel housing and mounts.
- turbo systems for the Ford app may not clear the flywheel housing and the manifolds may be different anyway
The S-series mentioned by 82F100SWB is a good place to look for most of the parts involved.
Ken
Old Dec 18, 2018 | 10:59 PM
Ty Gonalez's Avatar
Ty Gonalez
Quick question.
quick dumb question, would my 95 7.3 powerstroke have the same style bell as the IDI ?I'm looking at doing a 9spd conversation as well
Old Dec 18, 2018 | 11:24 PM
ford390gashog's Avatar
ford390gashog
Yes same thing, just remove the ford adapter that is there now the SAE pattern is underneath. Unless you have a donor the swap is almost 5k with all the parts.
Old Dec 20, 2018 | 09:55 AM
RaymondIV's Avatar
RaymondIV
More to it than that, first you have to have an onboard air supply, second, unless they've changed in recent years, all the (Eaton Fuller) Roadrangers use a double disc pull clutch which would require a lot of re-engineering for mechanical clutch linkage from bell housing to clutch pedal. Plus an IDI SAE bell housing won't have the bores on each side of the housing for the fork shaft that a pull clutch uses.
C-Jones Lawn & Tree
Large Truck
Jan 28, 2016 11:26 PM
rje
Dec 10, 2015 01:58 PM
phillips91
Large Truck
May 13, 2015 12:44 PM
johnday
Large Truck
May 12, 2015 06:40 PM
oleman
Large Truck
May 26, 2011 04:03 PM
