300 cu incher
Old Dec 23, 2002 | 08:01 PM
ford_nut's Avatar
ford_nut
300 cu incher
Guys,
today a friend gave me an 85 ford F250 for free. He says the motor is toast but im not so sure. It has a 300 in in. when he cranked it, it cranks unevenly--fast then slow then fast again--like there are cylinders that have screwed up compression. Funny thing is, once he gets it to run, it makes this horrific backfiring out of the carb on a regular basis as it runs. What the heck could cause this and where do I start first? I am only used to working on those ole FE's is a 6 any good? If i wanted to sawp it out for a V8, what would be a direct bolt in? The truck has a 4 speed in it now and the truck is a 2wd!
thanks again
regards
~~NUT~~
Old Dec 23, 2002 | 08:47 PM
kaotikedge_111100's Avatar
kaotikedge_111100
300 cu incher
>Guys,
>today a friend gave me an 85 ford F250 for free. He says the motor >is toast but im not so sure. It has a 300 in in. when he cranked >it, it cranks unevenly--fast then slow then fast again--like there >are cylinders that have screwed up compression. Funny thing is, >once he gets it to run, it makes this horrific backfiring out of >the carb on a regular basis as it runs. What the heck could cause >this and where do I start first? I am only used to working on those >ole FE's is a 6 any good? If i wanted to sawp it out for a V8, what >would be a direct bolt in? The truck has a 4 speed in it now and >the truck is a 2wd!
Sounds to me like your spark plug wires may be switched around in the wrong firing order, possible loose plugs as well. The inline six is a very good motor, they run forever if you take care of them. I have on in my 78' 2wd. As far as swapping one out, any of the ford small blocks will bolt right in, the 302, 351c/m, and the 400. You would need a bigger radiator and new engine mounts though, let us know what you find out.
Mike
Old Dec 23, 2002 | 08:55 PM
brown 4x4's Avatar
brown 4x4
300 cu incher
The 351m and 400 won't bolt up to your existing tranny as they have the big block bolt pattern.
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old Dec 26, 2002 | 06:00 PM
Ford_Six's Avatar
Ford_Six
300 cu incher
Old Jan 1, 2003 | 09:31 AM
MSTRAWN's Avatar
MSTRAWN
300 cu incher
Back firing through the carb can be caused by a defective vacuum advance unit on the distributor. Check the unit with a vacuum guage/pump like the mighty mite or similar unit. Most parts stores can check this for you as well. Replacement cost is about $10.00.
Old Jan 1, 2003 | 09:58 AM
wildjon300ci's Avatar
wildjon300ci
300 cu incher
Also, go invest in a good compression tester before you get into replacing everything. Good readings are around 160 psi, if any of the readings are below 135 psi then I'd say rebuild it or swap it for something.
Old Jan 3, 2003 | 05:56 AM
inliner's Avatar
inliner
300 cu incher
My motor did that once when the valve adjustment was too tight. The valves were hung open and the motor would spin really fast.
Old Jan 3, 2003 | 06:02 AM
Nod's Avatar
Nod
300 cu incher
Sounds like the same noise my 300 made with a blown head gasket between #1 and #2 cylinder.A rebuilt motor fixed my problems!
"bowties in the rearview mirror"
Old Jan 3, 2003 | 02:03 PM
ford_nut's Avatar
ford_nut
300 cu incher
Guys
Im gonna do a compression test tomorrow--ill post back the results!
thanks again!
regards
Ben
Old Jan 3, 2003 | 04:30 PM
truckzilla's Avatar
truckzilla
300 cu incher
If it wasn't for the fact that you are on the right coast and I'm on the left coast, I'd be happy to take that engine off your hands if you decided to swap it out.
chaosmoosie
2009 - 2014 F150
Mar 14, 2017 11:17 AM
Firefighter 1406
56
Jan 5, 2017 07:21 PM
raye321
Dec 20, 2015 05:07 PM
2006lariat
Jan 30, 2014 06:22 PM
The Punisher
Apr 21, 2005 12:33 PM
