Cranks real fast cold, wont start unless warm?
A coworker of mine has a 2004 F-350 psd that crank's real fast cold but wont start. When warm it crank's normal, and start's right up.
He said he has to plug it in, or it wont start, but when he does get it started it runs great. Local garage tells him the HPOP is shot.
He has recently bought an FICM from Ed, a DC alternator from ed, and had 2 injector's replaced, and 2 new battery's. This truck only has about 40-50,000 miles on it. It has the ICP in the valve cover.
What do you all think?
Ironically, He uses it to plow snow. So not starting in cold is a bit of a problem!
Edit: He is very garage reliant, which is fine, but we don't have a good diesel tech locally. The reason he put 2 injector's in was because the dealer broke the FICM harness installing his FICM, and rather than double check it, he (The tech) pulled the injector's.
A redneck way to check the FICM is to use a hair dryer or heat gun on the FICM then do a cold start. If it starts better the FICM is bad.
You sort of see that with the better starting with the block heater plugged in. The heat soak also warms up the FICM allowing it to work better cold.
The temp sensors, nor the glow plugs are not the issue with this engine.
Josh
Josh
I wouldn't rule out the GP's....
Last winter I would have to plug in my block heater if my EOT and/or ECT dropped below 40 degrees and after a glow plug change this summer I have started with no problems as low as 10 so far.
I wasn't getting any cel codes either.
side note.... 100 bucks for the plug wire pulling tool and the plugs and took me 2 hrs start to finish for all 8 plugs on an august afternoon has made my winter so much easier
~Josh
~Josh
I have a friend that has a 6.0 and is having a same issue........replaced the glow plugs .....still will not start .....so I asked him what type of oil he as using......mind you the temps here have been below 32.....so he says ......rotella t 15-40.......could that be the problem ?
Should still start "ok" down into the 20s with 15/40 though.
Josh
Josh
