6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
exhaust smoke while driving
Old Nov 29, 2007 | 08:46 PM
  #31
rob_nc's Avatar
rob_nc
Originally Posted by AlbyVA
So what you are saying, is that if you see Black Smoke, the DPF is broken and whomever should get it fixed ASAP since its most likely still under warranty?
But those with White Smoke are fine? As I read, it seems like White Smoke is normal, its just a regen that isn't regen'ing at the right temp? But nothing terrible is happening?
You are correct. The dpf is there to remove ALL black smoke. White smoke is raw hydrocarbons (fuel). Ever see a semi fire up in really cold weather? It will puke white smoke until the engine is warm enough to burn all the fuel that is being injected. The same theory is true when a regen is initiated. When the DOC is too cold to burn all that is being injected into it, the unburnt fuel escapes as white smoke.
Old Nov 29, 2007 | 09:41 PM
  #32
Zeplik's Avatar
Zeplik
So while I agree with you that some white smoke may be normal, what also happens is the engine bogs down, and sometimes it seems the transmission isn't finding the right gear. I'm unclear in seeing how a cold DOC would impact engine power like this. Also, it happens after the engine is well warmed up, like hours of driving.
BTW as reported if you back off the throttle, it fixes itself, but I've also tried hitting the throttle harder to see what happens and often times that too will seems to fix it. It's almost like the transimssion finds the right gear, the engine RPMs hop up, and voila, no more smoke.
Any thoughts on how this can be?
Old Nov 29, 2007 | 09:57 PM
  #33
AlbyVA's Avatar
AlbyVA
Originally Posted by fordfish
AlbyVA, looking at your recorded mpg's you are filling up weekly and getting 10-12 ish I'd say you do alot of intown driving, me too, this seems to create alot of regen burns, I think you are just seeing DFP crap exit the tail pipes.
Yup. You are correct. The majority of my driving is local intown.
mcali2
Aug 10, 2016 07:11 AM
kfor08
May 20, 2016 05:45 PM
Mercniac
19
Nov 21, 2015 01:05 PM
dynarider33
Nov 11, 2015 05:23 AM
Vibrant93
Jul 7, 2014 10:26 PM
