exhaust smoke while driving
while driving about 45 mph on two occasions i have noticed white exhaust smoke for a few seconds. i am pretty sure it is when the truck starts a regen as ford has pu in tsb's. truck ran fine not problems during the smoke, but was a decent amount of smoke. has anybody else noticed this? i am not too concerned, but sure do not want a cop to pull me over for smoke.
getting both black and white smoke
I have over 11,000 miles and have been getting both black and white smoke. Brought it in for the black smoke, they couldn't fine anything wrong, said it could be the diesel i was buying from station. Nah, they ain't it. Complained about the bluish/grey/white smoke when accelerate hard especially when turning off of the interstate. It usually does it after I have been driving a while at highway speeds. It shutters real bad like its flooded. Nothing known on that yet. I have been doing more city driving lately and its not as noticable, but will have to get it fixed, cuz it sure isn't normal. There are quite a few post regarding the white smoke with jerking as accelerating.
I've had the same issue and mentioned previously in another thread. Stuttering / whitesmoke / etc. usually when accelerating onto the highway. I took it in to be looked at by Ford mechanic. Initially he thought it was related to the OVER FULL OIL / FUEL IN OIL TSB, but nope, not it. Oil OK, no residue in pipe, injector seals good. Test drives of course could not reproduce the symptom. He had several discussions with Ford Engineer about this, but was told that it's related to REGEN (hogwash!). I'm now to the point of keeping a log of when it happens, driving conditions, rpms, engine temp, heater / AC activity, and whatever else I can think to write down at the time. Somethings got to turn up eventually! One thing that would greatly help, I wish the communication display would alert you to when the engine is in REGEN. A simple asteisk in the corner would have been fine!!!!! FOMOCO, are you listening?
BTW I have over 12K miles on it, and have had the REGEN IDLE RPM /SMOOTHER SHIFTING flash performed. I absolutely LOVE this truck in every other way!!!
Zeplik,
What re-flash? I have not kept up with whats going on with Ford. I do have the high idle when in regen, and my transmission has always shifted very rough. Does the reflash fix those things?
My truck has been barfing black smoke since about 3000 miles or so. It has black residue in tailpipe, but thats when mechanic said it was probably the fuel i was buying at the stations. That was hogwash. I'm tired of bringing it in and them telling me they can't duplicate the problem. It's too much of my wasted time. I agree with you on all else. The other big complaint I have is the fuel mileage. It has gotten alot worse in time, but overall the mileage is very poor.
I had a 2000 model w/ the 7.3 that got alot better than this one. I do like the way the truck drives tho. Hopefully, they will find the solution to our problem and get it fixed.
Geaux-Fish,
It's TSB 07-17-3. It's applicable for builds before 7/30/07 only. I found it did make a significant improvement on upshifts. I also saw a reduction in RPM and the amount of idle regens I was having, though it does not eliminate them. There are several other fixes addressed by this TSB that I was not experiencing. Check it out and see what you think.
Originally Posted by Buckarcher
This happened to me to day for the first time. 7800 miles on the truck. White smoke (a lot of it too) coming out any time I was in the throttle hard or easy for about a mile. The truck had been running for about 10 minutes. Would the DOC still not be hot enough after that long?
Nope, it takes awhile and casual driving or idling definitely doesn't help. The DOC needs to be ~275C (527F) before all of the fuel injected is burned.
I got the big huge white plume of smoke yesterday - I was towing about 1500 lbs for 2.5 hours - running at around 70mpg for most of that time - there was an accident - had to slow down for a little while - putted along at 20mph for 5 min- when everything cleared - got on the accellerator - TONS of white smoke and sputtering. grrr.
I also get sputtering/hurking/jerking when towing and the motor is trying to upshift - at around 55 mph... I just have to get out of the accelerator and all is well.
Maybe this is all regen related.. Sure would be nice to have a REGEN ON button - hell I would put my truck through a regen every time before I towed..
Had all updates done at dealer - cant find anything wrong...
GRRRR
GRRRR
