cam and intake
Old Jan 3, 2003 | 03:29 AM
gkelso's Avatar
gkelso
cam and intake
About how much horse and torque power would I get from my engine if I swapped in a rv cam and offy dualport intake. Its a '79. I plan on doing this much now and later doing the exhaust and carb. Thanks.
Old Jan 3, 2003 | 11:19 PM
gkelso's Avatar
gkelso
cam and intake
Old Jan 5, 2003 | 04:23 PM
whittey's Avatar
whittey
cam and intake
STOCK:
http://bigblocksix.com/dyno_runs/stock.png
Stock w/DP, 500cfm 4bbl, Comp Cams 252 cam:
http://bigblocksix.com/dyno_runs/stock_dp_500_252.png
-=Whittey=-
Old Jan 5, 2003 | 04:47 PM
Njbmx's Avatar
Njbmx
cam and intake
how did you get the 300ci. six for the desktop dyno? the only one i see is the dodge slant six.
pete
Old Jan 5, 2003 | 05:12 PM
AKFord's Avatar
AKFord
cam and intake
Whittey,
I couldn't see what you had there, just a couple of little boxes with red Xs in them. What numbers did you have there. Thanks
Old Jan 6, 2003 | 10:56 AM
whittey's Avatar
whittey
cam and intake
Sorry, my web server is down. I don't recall the exact numbers, but maybe 160 or 170. Check back later (after 6pm EST) and the pics should be back up again (maybe earlier if this snow scares my workplace and they send me home early).
As for how I got the Ford Six in there, I put it in manually. The flow head data I got off a post in fordsix.com BC (before crash).
-=Whittey=-
Old Jan 8, 2003 | 08:00 PM
rhetor's Avatar
rhetor
cam and intake
whittey, is there anyway i could get you to email me that config file for the I6? I don't really know my way around desktop dyno. I used it twice i think =D
Old Jan 8, 2003 | 11:18 PM
benwantland's Avatar
benwantland
cam and intake
>I plan on later doing the
If you put a four barrel intake on now, you will want/need to do the carb now as well. I don't think there is a ready made adapter for your one barrel to a 4b intake, and even if you could, why? Just save your bucks until you can do at least the carb and manifold together.
Old Jan 9, 2003 | 07:40 AM
whittey's Avatar
whittey
cam and intake
rhetor: Shoot me off an email (address is in my profile (the head-shaped icon under my name)) and tell me specifically what you want.
-=Whittey=-
Old Jan 9, 2003 | 05:15 PM
Ford_Six's Avatar
Ford_Six
cam and intake
Hey, whittey, the cam timing stock is retarded 4*. The actual HP is aound 125, and the torque is 210 for a stock motor. This is something to keep in mind for a cheap power boost. If you replace the timing gears with a straight-up set (like off- the- shelf Dynagears), you will loose a little top end, but it will make off the line performance that much better.
Jared
Old Jan 9, 2003 | 05:19 PM
Ford_Six's Avatar
Ford_Six
cam and intake
leviarps
Jan 10, 2017 07:12 PM
Haydendh
Oct 12, 2014 08:25 PM
daveyboy1
Sep 13, 2010 10:18 AM
Fishrman
23
Jan 20, 2004 04:55 PM
Rat wagon
Mar 11, 2003 07:39 PM
