1978 ford 400m
Old Jan 9, 2017 | 11:28 AM
leviarps's Avatar
leviarps
4wd Low
1978 ford 400m
hey guys, new to the page. i have some questions on cam choice. I have a 400m with an edelbrock performer 400 intake and edelbrock 600cfm carb, i will be adding summit racing longtube headers. I want to do a performance cam but dont know which is best. Im thinking either the comp cams xtreme energy XE284h cam or the comp cams thumper 287TH7, want performance with the choppy idle?
Old Jan 9, 2017 | 05:55 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Those seem wayyyyy too radical. I would recommend for something in the 270-275 range, .500-.570 lift. The choppiness I bet will be there. 400 seems to idle slightly choppy anyway being a square configuration.
Old Jan 9, 2017 | 06:26 PM
gatorfor88's Avatar
gatorfor88
And there is no such thing as a 400m.
Old Jan 9, 2017 | 06:32 PM
hivoltj's Avatar
hivoltj
2wd or 4wd? Manual or auto? What's the truck's intended use? Those are all important factors in cam choice. Choosing a cam by sound is dumb and a good way to have a turd of a motor.
Either of those cams u mentioned have a lot of duration, bad idea in a heavy truck with low compression.
Old Jan 9, 2017 | 07:44 PM
F-250 WARHORSE
Cam for truck, 112lsa is best and stay in that 500 lift range, you get much more than 500 lift, the driveability is deteriorated.
Old Jan 9, 2017 | 07:55 PM
Blue and White's Avatar
Blue and White
The 400 responds well to upgrades... the intake and exhaust will help. If you are running stock or similar pistons and heads, compression will be on the low side. Too much cam duration will bleed off cylinder pressure and kill torque. No fun.
I would suggest a cam in the 260 range for intake duration. Just as important, a straight up timing set and degree in the cam. Also important is matching valve springs... the stockers are not suited for a bigger cam.
Your choice performance mufflers will give it the sound you want.
Old Jan 9, 2017 | 09:10 PM
leviarps's Avatar
leviarps
4wd Low
There is such a thing, its the 351m/400(6.6), i have two trucks with these motors in them.
Old Jan 9, 2017 | 09:12 PM
leviarps's Avatar
leviarps
4wd Low
I will be doing a while cam kit, witch will include all of those components, thanks for the help, its greatly appreciated
Old Jan 10, 2017 | 05:31 AM
Bud Mud's Avatar
Bud Mud
No, no theres not, do your home work. You have in those trucks either a 351m or a 400, there is no 400m, never has been never will be. Good luck with your build.
Old Jan 10, 2017 | 12:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Been here lately? 335 Series- 5.8/351M, 6.6/400, 351 Cleveland - Ford Truck Enthusiasts Forums
X2 on yes 351M and yes 400, but NO 400M.
351C with a M code yes.
The M-code was a high-compression, high-performance variation of the 351C, produced in 1970 and 1971. The M-code engines used the large-port 4V heads with a closed "quench" combustion chamber and large valves.[3] These engines also included cast-aluminum flat-top pistons, stiffer valve springs, a high-performance hydraulic camshaft, and a squarebore Autolite 4300-A carburetor.[1] The 1970 engines were 11.0:1 compression and produced 300 bhp (224 kW; 304 PS) at 5400 rpm, while 1971 versions had a slightly lower compression ratio of 10.7:1, and produced 285 bhp (213 kW; 289 PS) at 5400 rpm.[3] The M-code 351C required premium fuel and was available in the 1970-71 Ford Torino, Mercury Montego, Ford Mustang, and Mercury Cougar.[11][12]
https://en.wikipedia.org/wiki/Ford_335_engine
Bubba's M-Block Ford V8 Workshop
Great info on power up. M-Block 351M/400 History
Ford 400 and 351M Performance Upgrades and Parts - FordMuscle
Old Jan 10, 2017 | 12:53 PM
Aaron-71's Avatar
Aaron-71
Thanks for adding content to the thread fellas. Real helpful for new members.
What these two are picking at is the fact that you have an "m" next to the "400" in your original post (O.P.).
Instead of giving you some advice, they chose to pick apart what you said. Technically, they are correct. There's no such thing as a "Ford 400 Modified" - it's just a Ford 400. Were they right to do that when all you're looking for is some advice? No... definitely not.
Hopefully it doesn't ruin your experience on FTE as a new member. Btw, Welcome to the forum . Regardless of whose right or wrong, it's good to have new members show up on the forum to keep these old Dentsides running.
Now on to what you were looking for.
Hivoltj's suggestion is quite right... it depends on what you have currently in your truck (current specs) and where you intend to go with your truck (your wishlist/wants).
List some specifications for your truck for us so we can get a better idea of what you've got in the truck. 2WD? 4x4? Front/Rear end gearing ratios? Tire size? Transmission (Auto/Manual)?
What's the intended purpose of the truck? What is its job right now?
Cam selection is very important. Choosing the wrong cam can have dire consequences for your build. Tell us some important details on your truck and we can help you out.
Old Jan 10, 2017 | 06:00 PM
gatorfor88's Avatar
gatorfor88
Oh dear. I have been chastised by a canadian. What ever am I to do?
Old Jan 10, 2017 | 07:12 PM
77&79F250's Avatar
77&79F250
Lets not let this forum get to be like others out there. Sometime a short answer is good, but a short answer with some supporting info is even better.
str8piped79
28
Mar 18, 2012 07:01 PM
AntiHero55
Jun 15, 2010 02:54 PM
ladiabla74
Dec 23, 2007 03:51 AM
MBBFord
Jul 24, 2005 02:06 PM
mstum00
Jan 10, 2005 09:46 PM
