External Transmission Filter
Old Oct 19, 2007 | 04:31 PM
tow2atm's Avatar
tow2atm
Question External Transmission Filter
Does my 2005 have an external tranny filter? I have the torqshift transmission. If so how often do you recommend changing it? And is there another filter inside the pan?
Old Oct 19, 2007 | 05:17 PM
18vtx00's Avatar
18vtx00
yes there is only an external by the right frame rail in the front o fht truck and not one in the pan just a pickup is all. I would say every 30K when you shoudl flush it as well...don't forget the transfer case too.
Old Sep 24, 2008 | 02:51 PM
adamsre's Avatar
adamsre
there is one in the pan also, not just a pick up. Ford says no need to change the one in the pann but I say I feel better to change it.
Old Sep 24, 2008 | 04:30 PM
sonneborn3's Avatar
sonneborn3
What's the best way to go about flushing the tranny, is it something I can do myself, or would it be better to go to a quickie lube style place, or a dealer?
Old Sep 24, 2008 | 04:35 PM
riggz's Avatar
riggz
The process is in the workshop manual, however it is a bit involved. if you do have someone else do it, take it to the dealer. I wouldn't trust a quikie lube joint to put in the correct and required fluid.
Old Sep 24, 2008 | 05:37 PM
69cj's Avatar
69cj
If you are interested, the ext. filter # is Motorcraft ft-145. Book says change every 15,000 miles. Do every 10,000 if towing, my opinion only. The only fluid to be used in the torqueshift tranny is Mercon SP, no substitutes if you value your tranny. SP is only available thru Ford.
navyjuice
Jun 3, 2019 11:03 PM
Restlesswildman
Jun 16, 2015 02:37 PM
whporwil
6.4L Power Stroke Diesel
Dec 23, 2011 02:25 AM
gvandyke
Oct 17, 2007 06:37 PM
jobguy
Sep 17, 2004 08:36 AM
