Need Throttle Position Sensor
Old Oct 19, 2007 | 12:58 PM
947.3turbo's Avatar
947.3turbo
i need a TPS for my 94 f-250 turbo 7.3. so if anyone has 1 and dont want an arm and a leg for it plz let me know asap! i need the truck runing again
Old Oct 19, 2007 | 01:11 PM
Cuda_jim's Avatar
Cuda_jim
Welcome to FTE, most guys here aren't going to part with their extra TPS if they have one but there are other things that may get you going again. BTW: It's called an Accelerator Pedal (AP) sensor. If you ask a parts dealer for a TPS you'll get the wrong one. Click the link in my signature for part numbers.
Are you sure you need one?
Old Oct 19, 2007 | 01:54 PM
947.3turbo's Avatar
947.3turbo
yea im sure i need it. when i drive it it the check engine light comes on and it go to idle no mater how much i hit the gas. i took it to a diesel shop and they said i needed 1. so i called ford ans they said it came with the pedal, and could not just get the sensor, and it was goin to be like $700. and thats y id like to find a used one. so i called some junkyards round here and noone had any. and thanks for the info too
Old Oct 19, 2007 | 02:05 PM
Cuda_jim's Avatar
Cuda_jim
Yep, they are expensive from the dealer. They are the only game in town for a complete assy. MOst junk yards know how much thet cost and will soak you too.
There is just a sensor for replacement but I havn't heard of anyone that has made it work. Wish I had better news for you. It's about $45
STANDARD MOTOR PRODUCTS Part # TH35
DORMAN Part # 699200
BTW: There are 2 sensors on the accelerator IVS (Idle validation sensor) is the other one.
Take a look at the connectors for bent or pushed in pins. The side to side movement will cause it to act up too, as explained in the link I gave you.
Old Oct 19, 2007 | 02:48 PM
Action4478's Avatar
Action4478
Have you looked here?.....
Old Oct 19, 2007 | 02:54 PM
tjbeggs's Avatar
tjbeggs
this is the cheapest I have seen them run new
http://catalog.powerstrokeshop.com/p...ts&searchAll=1
but its still a hosing! I bought one used for $100. Let me see if I can find another one for you.
Old Oct 19, 2007 | 02:55 PM
1997F-350's Avatar
1997F-350
check here and the tds classifieds for a used pedal. i bought a spare off there a year or two bakc for 80 bucks to keep behind the seat. i sold it though sorry.
also the 96+ pedal will work on your truck and its a lot cheaper than your year. its like 150 iirc. good luck
Old Oct 19, 2007 | 05:14 PM
sbraatz's Avatar
sbraatz
You might try dormanproducts.com. They have them listed for $59.00. Let us know how things work out.
Old Oct 19, 2007 | 06:21 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I've got mine for PS shop . com After having 2 act up I'm keeping a new one on the shelf.....
Old Oct 21, 2007 | 08:04 PM
947.3turbo's Avatar
947.3turbo
thanks for all the help guys ill fig out which 1 in goin to go with tonight prob. so ill let yall know what happens
Old Oct 21, 2007 | 08:44 PM
tjbeggs's Avatar
tjbeggs
I have tried to find you a used one and it seems its a no go. Sorry.
Old Oct 25, 2007 | 08:11 PM
947.3turbo's Avatar
947.3turbo
ok i called a few people i know and found one in FL at a dealer. i got the pedal and everythign for just over $200 with shipping. they marked it down 50% off of the price they payed for it. i think i got off good on that ****!
Old Oct 25, 2007 | 08:18 PM
tjbeggs's Avatar
tjbeggs
Nice!! can't beat cheaper (well cheaper!)
Old Nov 11, 2007 | 02:50 PM
Upper's Avatar
Upper
OK I am new to this diesel deal,When I am out in the field it is hard to idle along or feather the pedal.Is this a different problem than what this thread is about?Thanks Upper
Old Nov 11, 2007 | 03:47 PM
jboard's Avatar
jboard
I would do some checks first if I was you. I had a problem a while back and found this:
https://www.ford-trucks.com/forums/6...ml#post4651464
----------------Jeremy
897.3idi
Jan 8, 2012 02:15 PM
Talyn
Tennessee Chapter
May 22, 2010 08:43 AM
ltl_jrw
Dec 1, 2009 03:31 PM
CHACH
Sep 30, 2003 06:54 PM
PowerbyFord
Apr 15, 2002 04:39 AM
