Sponsored by: Real Truck
Flush mount cab lights???
Old Oct 18, 2007 | 11:00 AM
  #31
JB666Rock's Avatar
JB666Rock
Well, the same set of lights are stopping me from going through my laser car wash, too.. So I could kill two birds with one stone.
Originally Posted by Beerstalker
Which part are you close to hitting the door or the door opening? I believe there are kits to make the door open up further if it is hanging down a few inches lower than the opening.
Old Oct 18, 2007 | 03:23 PM
  #32
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Tungsten
...the little arm that raises and lowers the garage door would rake right down the roof of the truck.
You can get garage door openers that act directly on the jackshaft. No arm hanging down to drag on stuff.
http://www.liftmaster.com/cw/product_family/0,1064,uid-iXKCbmFhamxkaA==_1197-id-42,00.html
http://www.wayne-dalton.com/idrive_Torsion.asp
I have the Wayne-Dalton one and it works well enough but needs recalibration every now and then. The LiftMaster one is supposed to be better.
Old Oct 18, 2007 | 08:49 PM
  #33
JB666Rock's Avatar
JB666Rock
I run the LiftMaster and have had great luck with it...
Old Oct 19, 2007 | 01:04 AM
  #34
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Here you go this should fix everything, no bull sh-t like letting the air out of your tires, building a new garage, duct tape (I prefer HVAC tape it looks like chrome ). Just a solution so you can put the beast in the garage. They make several sizes of these but this one is 3" long by 7/16" tall and they look sharp. The local AC Delco store carries the full line so I have seen them and they are nice.
Good luck.
Dave
http://grote.com/product.php?product_number=47952
Old Oct 19, 2007 | 07:39 AM
  #35
Dogwood36322's Avatar
Dogwood36322
Put in a 9 ft door. They make them and all you have to do is mod the door opening.
Old Oct 19, 2007 | 08:48 AM
  #36
JKBrad's Avatar
JKBrad
The cab lights used on 88-98 GM trucks are not very tall. You might look into those.
Old Oct 19, 2007 | 09:02 AM
  #37
JB666Rock's Avatar
JB666Rock
Hey thanks! I like those. I'll look into them a bit more later today!!!
Good luck.
Dave
Old Oct 19, 2007 | 10:01 AM
  #38
77hiboyboy's Avatar
77hiboyboy
Those grote lights aren't p2c rated. They shine straight up instead of different angles. Contact a big truck chrome shop, 4-state truck parts Joplin MO. 75 chromeshop in florida, or Elizibeth truck center in New Jersey, or any bigger chrome shop. Ask for "bulkhead" led's. They are a small led that trucks with shaved roofs (clearance lights) run to be legal at night, but remain shaved looking in the daytime. They are only like 10-12 bucks a piece. Truck-lite also makes a small light that is p2c rated in amber that is smalled than a head of a penny. I would have posted phone numbers but have got my butt chewed here for moderators thinking I wasn't promoting vendors.
Old Oct 19, 2007 | 02:37 PM
  #39
z71burb's Avatar
z71burb
these WILL work - but i think you might have to drill one more small hole for mounting - but they do fit the contour of the ford roof.
http://www.gorecon.com/product.php?p...03-08&p_cat=29
Old Oct 19, 2007 | 02:43 PM
  #40
JB666Rock's Avatar
JB666Rock
I actually called Recon yesterday and they told me that those were the exact same height as the factory covers..
http://www.gorecon.com/product.php?pk=67&pname=Part+%23+264146BK+-+SMOKED+Cab+Lights+Dodge+03-08&p_cat=29
Old Oct 19, 2007 | 02:53 PM
  #41
Storm's Avatar
Storm
I just talked to the guy that owns that Striker Truck with the Cab Light picture.. Him and his Son built it up.. However he took my information down, they are going to be producing those Cab Lights.. They are waiting on the cast parts to come in and they will be offering them up and sending out Price Lists.. If you are interested in them, call Paul at 541-474-1980 Hulst Customs and he'll get your info.. He said they will be relatively cheap as they are direct bolt ons.. Those things are SHARP!
Old Oct 20, 2007 | 03:31 PM
  #42
truckeemtnfords
No where can I find what type of truck he has, DRW or SRW. If it is a SRW he does not need p2c rated lights as they are not required unless the vehicle is over 80" wide, i.e. DRW. I would have to do some research but I don't believe the cab roof clearance lights have to be rated anyway, only the side and rear lower lights so than can be seen at a greater angle.
Storm did they say how tall those light are?
Dave
Old Oct 20, 2007 | 08:54 PM
  #43
Storm's Avatar
Storm
Dave
Half the size of the stock ones
clintusaf
Feb 11, 2015 12:50 AM
stretch5881
Nov 23, 2014 04:07 PM
Daddyo's garage
22
Mar 7, 2014 08:30 PM
rtazz17
6.7L Power Stroke Diesel
50
Feb 22, 2014 02:52 PM
Father Donald
Dec 20, 2013 12:14 PM
