Ok... I've been digging and can't find any conclusive explanation of how to easily adapt a t5 behind a 223. Some must have done this. How do you connect them and what is the parts list?
if memory is correct i think speedway carries the bell housing for the T5. it also states that u WILL need to use another starter, there's of course. i recall the housing is around $200 and the starter is maybe $300..
What year is your truck? If it is 53-on, the bellhousing with mounts will be too deep, the T5 input shaft won't reach into the pilot or clutch disc. You'll have to use a different BH.
You can't really "weld" a lug onto a cast iron BH. I'd go with a steel car BH and add a rear crossmember. I'm not sure how the truck clutch linkage would interface with the car BH's clutch arm, but they are pretty similar on the surface. I have a steel car bell if you are interested.
NOTE -- I just re-read that linked post; the guyh is doing the T5 on a Bonus Built, not at all the same animal!
You might want to check your facts...you CAN weld cast iron. How do you think Mumerts modifies their bell house?
