Sponsored by: Real Truck
Flush mount cab lights???
Old Oct 17, 2007 | 07:05 PM
JB666Rock's Avatar
JB666Rock
Is there any such thing??
I can't be the first guy that can't fit in his garage because of the cab lights standing 2" off the top of his roof
Anyways, I've searched high and low, and I can't find anything. I've got an 06 F350 w/6" of suspension lift and 35" tires. I could make it in my garage if it weren't for the cab lights...
Any suggestions, besides "jack up your garage"???
Old Oct 17, 2007 | 07:16 PM
nobodyspecial's Avatar
nobodyspecial
Air down your tires. Hey, you said any suggestions besides jacking up your garage
How close is it? I am sure you could find some aftermarket lights that arent so tall.
Old Oct 17, 2007 | 07:19 PM
JB666Rock's Avatar
JB666Rock
I need lights that would almost be flush mount, or at least 1/2 that of the factory covers. With that in mind, I obviously couldn't use the factory bulbs, because they'd be too big. I was hoping for a new light setup that used LED's.
And believe me, I was looking for one of the tire deflation systems that you'd find on an old Hummer H1, but I can't find that kit anywhere either.. I've already got an onboard compressor & tank because of my train horn(s) setup.
Old Oct 17, 2007 | 07:56 PM
nobodyspecial
That might be a tougher task, incorporating a CTIS (central tire inflation system) to your super duty - not saying that it couldnt be done, but I think it would be a lot easier and cheaper to find some different clearance lights.
Old Oct 17, 2007 | 08:10 PM
JB666Rock's Avatar
JB666Rock
That's what I'm hoping.
Old Oct 17, 2007 | 08:36 PM
mastercaster's Avatar
mastercaster
Smile
go to a 4" lift
Old Oct 17, 2007 | 08:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
I know my truck would not fit in my garage if I install clearance lights. I don't get it in the garage that much, anyway.
There is a company that makes brake light kits for hot rods, they are flush mounted into the body then painted over. When the lights are off you cannot see them, it just looks like smooth body. When you turn them on the light shine through the paint. I don't see why this wouldn't work for clearance lights, although it would be a royal PITA to fabricate. (It would look cool, though)
Looking at the lights themselves, you could probably gain about 1/2 inch clearance with some creative trimming, using a Dremel. It probably wouldn't get you enough clearance.
Old Oct 17, 2007 | 08:43 PM
XHunter's Avatar
XHunter
march '07 Diesel Power Mag...F350 with custom cab lights
this should point you in the right direction
if the link dosen't work go to www.dieselpowermag.com then features pages 2 near the bottom...F350 with B&W cobra paint scheme.
http://www.dieselpowermag.com/features/ford/0703dp_2007_ford_f350_superduty/index.html
Old Oct 17, 2007 | 08:49 PM
redford's Avatar
redford
Here's an example of the flush mounted brake lights I was talking about.
Clearance lights could be done the same way, so they would vanish when not in use.
z71burb's Avatar
z71burb
the guys at recon accessories told me that some people get the dodge ram led marker lights for their fords. i think you have to drill one hole, but other than that they fit the contour of the roof and are a good deal shorter than the stock ford cab lights.
Old Oct 17, 2007 | 08:52 PM
JB666Rock's Avatar
JB666Rock
Now that's really cool -- Thank you!
Old Oct 17, 2007 | 09:14 PM
TP83's Avatar
TP83
stupid question, but why do you need the cab lights?
Old Oct 17, 2007 | 09:16 PM
mstiles19's Avatar
mstiles19
haha before you pull into the garage just load the bed up with some weight(sandbags, water, midgets, ect.?)
or better yet jackhammer out the floor of your garage....
Old Oct 17, 2007 | 09:20 PM
JB666Rock's Avatar
JB666Rock
WOW this site is slow.. But that's a story for another day.
Anyways, I don't "need" them, but they are factory equipment and I'm not removing them to leave (5) nice holes in my roof.
Old Oct 18, 2007 | 09:32 AM
Beerstalker's Avatar
Beerstalker
Which part are you close to hitting the door or the door opening? I believe there are kits to make the door open up further if it is hanging down a few inches lower than the opening.
