Schaeffer's oil anybody?
on
Anybody here running Schaeffer's 7000 (15W40 blend) or 9000 (5W40 full synthetic) oil? Rotella 5W40 didn't work out for me but I was wondering if anybody was running this stuff and if they had any oil anaylsis after running it? I have consistantly had higher than average iron readings in the 5 UOA I have done and would like to get it to go away.
on
quite possibly. I already knew I have more blowby than I should and #6 fails a contirbution test. i don't know if its from my turbo destruction or if it was like that when I bought the truck. Either way it still runs good and starts fine even in the cold. blackstone said not to worry about the high iron. its still not in the alarm category just higher than the average. I like to be below average for some things!
here is a link to my UOA
http://good-times.webshots.com/album/558328994MTZxBe
on
Originally Posted by arkredneck
can't some truck stops do a oil anaylis and if so how good is it at telling you how worn out your engine is?
If its used as maintence then it becomes much better for diagnostic as you can see trends starting or catch problems early.
on
Originally Posted by MADVAN
TJ
The 9000 is real good stuff.
On the failed cont test. Dont over rule a bad hole. It could be injector related.
Bill
Bill
Also I am hoping for an injector issue. I will find out when I put my stage 1's in ( if I ever get them built!) I will also be doing a compression test while I am in there and I am contemplate a set of 910-16 valve springs.
