Trim accent removal questions
10-17-2007, 01:50 PM
on
I removed the trim strips that divide the two-tone paint. I am wondering if anyone knows a trick to remove that gunky adhesive without damaging paint too much.
10-17-2007, 02:12 PM
on
razor and window cleaner spray window cleaner on and hold razor blade almost flat with paint just dont gouge
10-17-2007, 02:28 PM
on
you could also try some cleaner and a soft scrubber of some sort
10-17-2007, 02:40 PM
on
Nice....I tried it out.....works pretty good....just gotta be patient.....thanks
10-17-2007, 02:55 PM
on
10-17-2007, 03:52 PM
on
Best thing to use is naptha (lighter fluid).
It is a natural solvent for the glue and won't hurt paint.
10-17-2007, 04:50 PM
on
I used Goof Off and a credit card for scraping. It also helps if the surface is warm.
10-17-2007, 06:03 PM
on
Use WD-40 no razor blades.
