dealer cant find wire harness
Old Jan 1, 2008 | 04:43 PM
  #31
Izzy351's Avatar
Izzy351
Originally Posted by rbaker6336
think it is on 60
Yep -- it's a little west of 75 on Adamo Drive (Hwy 60)...
Old Jan 1, 2008 | 06:37 PM
  #32
zx250's Avatar
zx250
Of the next Riffraff East
You might give these guys a try www.directfordparts.com . They are a site sponsor and Mike or any of the guys are very helpful in finding parts a usually cheaper than local dealers. If you can't find it on there site, drop them an email with your VIN and the best description of what you want and they will find it. If they have any questions about what you need, they will contact you back and help you figure it out. He (Mike La Dow) sent me some parts diagrams to help me figure out what pieces I needed.
Old Jan 1, 2008 | 07:07 PM
  #33
farmdad's Avatar
farmdad
Most times the numbers on the Ford parts are engineering numbers, not the actual part number. Found that out working in Ford parts. Can be very frustrating when you think that you have the part no. when you go to the dealer and it doesn't match. A Ford "better idea". I don't know if this applies to Navistar though.
Old Jan 2, 2008 | 02:23 AM
  #34
Mach1's Avatar
Mach1
Just did one..If you need the numbers, I can post it from the box...
You better be sitting down when you hear the price...
~$600 bucks....
Might want to splice yours..
Old Jan 2, 2008 | 07:57 AM
  #35
barnbuoy's Avatar
barnbuoy
~$600 bucks....
PLEASE DO!!!(post the numbers)
did you notice the title of the subject?....well,.. dealer cant find butt-connectors EITHER!
ford DOES make connector pig tails...... "if i cut it off and bring it in they may be able to match it up and order one".......(insane)what if you CAN'T match it up? at least at this point it still runs....
Old Jan 2, 2008 | 10:02 AM
  #36
Mach1's Avatar
Mach1
Chuck, no problem,this is the whole wiring harnes for the engine, includes drivers side valve electrical connector then routes to all engine sensors, injector wiring, glow plug, alternator and even comes with the glow plug relays(but for $547 it better) list is $946...Oouch..
Hope this works for you..
BTW..No butt connectors should use solder and waterproof heatshrink, I use the heat shrink with the sealer in it..
Chuck i got it from Powerstrokeshop.com, talk to Ben..I had it on my doorstep in 4 days...
Good luck..
Old Jan 3, 2008 | 02:35 PM
  #37
barnbuoy's Avatar
barnbuoy
mach1--that sounds like the exact buggar...
what happened to yours??? where did it go bad?
this seems to be a pretty common issue-
i will give Ben a shout--looks like it wont be for a few weeks again though-
(we're back on the road) gonna have to wait for next home-time.
Old Jan 3, 2008 | 02:47 PM
  #38
barnbuoy's Avatar
barnbuoy
Old Jan 7, 2008 | 03:01 AM
  #39
Mach1's Avatar
Mach1
Chuck, I did one on a customer truck, sensor plugs were messing up, injector wires have problems as well..Post back when you get er done..
Old Jan 8, 2008 | 05:53 PM
  #40
barnbuoy's Avatar
barnbuoy
thanx mach--i certainly will.
Old Jan 8, 2008 | 06:24 PM
  #41
Uzumati's Avatar
Uzumati
ive done both the engine bay harness (800 bucks) and the sensor harness (400 bucks) both from trade motion. these harnesses an very option and vehicle config specific so sit down with a parts man starting with one of the above numbers and make sure you get the right one. The guy from trade motion stayed on the phone with me for an hour to make sure i got the right one. All in all not to bad a job about 2 hours on the sensor harness.
Old May 25, 2008 | 06:30 PM
  #42
barnbuoy's Avatar
barnbuoy
ok--there is an ad site on the 7point3 website that i was able to find harness pigtails. ordered them, and i've had them in my hot little hands for a couple months now
business has been busy so far this year(good!) and also trying to finish up the boat..
i've been kinda focused on that for a few months---home time has been a little limited lately.
but thought you guys might want to know about those pigtails for repairing instead of replacing the entire harness.....
i'll go there and try to find the direct link
Old Nov 4, 2015 | 11:19 AM
  #43
cehenryj's Avatar
cehenryj
F6TZ-12A581-AS
Originally Posted by Cuda_jim
If you send a PM to numberdummy here on FTE he will get the part number. He's a retired ford parts guy. Great guy, very helpful.
HeLP!!!
I need
F6TZ-12A581-AS
for 96 bronco
1996 Ford Bronco XL
V8 - 5.8L vin H 351ci - MFI GAS OHV
Mike321
May 2, 2017 06:49 AM
dbbldz
Mar 31, 2016 09:32 PM
fludoc
21
Feb 11, 2016 09:20 AM
Manofgod4life
Feb 2, 2016 09:07 PM
DISLFVR
Jan 31, 2016 07:27 AM
