Harness problems
Old Jan 30, 2016 | 08:32 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Harness problems
Hi all, been busy lately. I have what might be a big problem, the main harness on top of the drivers side valve cover I can't get undone, the bolt holding it together is stripped or the nut who knows? wondering if there is any way to take it apart otherwise.
As always any help is appriciated. Later, Bill
Old Jan 30, 2016 | 08:57 AM
white Buffalo's Avatar
white Buffalo
Hey bill, the bolt does not come completely out. After you loosen it up it will just sit in the saddle. Then there are some plastics clips holding the 42 pin connector in place.
Old Jan 30, 2016 | 09:01 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Originally Posted by white Buffalo
Hey bill, the bolt does not come completely out. After you loosen it up it will just sit in the saddle. Then you need to push on the side clips to pull the 42 pin connector apart.
Yes I realize that, it is stripped and I cannot get it apart..
Old Jan 30, 2016 | 09:18 AM
Tugly's Avatar
Tugly
I've never run into this before. If I were there, I'd get a flat blade on the sides to see if I could carefully coax them apart. Do you have any contact cleaner? That stuff penetrates pretty good and might loosen something up.
Old Jan 30, 2016 | 09:33 AM
SRBF150's Avatar
SRBF150
That's a problem-at least it will do until one arrives anyway.
With stripped nuts and the like, it's either turn the bolt while pulling apart hard in hopes some sort of remaining thread will engage and allow the two halves to separate or just overcome the stripped threads with force.
Old Jan 30, 2016 | 09:56 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Yes as of now I have no need to remove that valve cover, but it's one of those things , like a thorn -in-the-side type of thing.
Old Jan 30, 2016 | 10:58 AM
white Buffalo
Sorry Bill, I know u know your way around the 7.3L, I was hoping it was an oversight/simple fix.
In addition to what was mentioned above, I wonder how difficult it would be to drill through the bolt.
Old Jan 30, 2016 | 12:52 PM
mototrig's Avatar
mototrig
Would a pair of needle nose vise grips fit in there? That is what I would try.
Old Jan 30, 2016 | 06:40 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
It would have to be the bolt head, it's the only thing visible. Then it would be a trick to get enough pressure for the bit to cut.
Old Jan 31, 2016 | 06:24 AM
Tugly's Avatar
Tugly
The bolt is locked into the loose plug, removing the head just removes the head and leaves the bolt shank in there. The bolt won't come out until the connector is separated and you can then push it through the connector face.
Old Jan 31, 2016 | 07:25 AM
Walleye Hunter's Avatar
Walleye Hunter
I have a pair of fencing pliers like these with the Craftsman name on them and I find them as useful as I do my welding tip cleaning files and dental pick. Mine have a full 1/2" or so flat jaw all the way across the tip and these things will hold onto a bolt shaft with a single thread remaining out of anyplace it is stuck. They are also flat on the side and that hole there has teeth for gripping said bolt with almost nothing left sticking out of casting. I would get these out, grab that bolt head and pull while turning while another set of hands pried gently on the plastic block as Tugly has recommended.
Old Jan 31, 2016 | 07:27 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
This will have to wait until I can give it more time. Thanks all for the ideas.
Quick444
Dec 29, 2017 04:26 PM
Jamie Arceneaux
Dec 29, 2014 06:04 PM
lght1
13
Jan 15, 2013 03:58 PM
ponch37300
Nov 26, 2006 06:45 PM
justasammy
Apr 6, 2005 09:17 AM
