Stripped Wire Harness Connector Bolt?
As part of my ongoing P1393 troubleshooting, I’ve found that I can’t get the main engine wire harness separated. The big connector by the driver’s side valve cover.
I’ve cranked and cranked in the correct direction, but the plug never separates. I tried a cordless impact wrench and it still doesn’t move. (Edit -- the bolt moves very freely, but it doesn't push out one side (e.g. like removing the PCM) I can't figure out how to separate the two sides.)
Any tips on how to get it separated? Can I cut off the bolt head to get it separated?
Thanks,
Mike
Thanks,
Mike
About all you can do is hold on to the bolt with a needle-nose tool (I have needle nose vice grips) and drill the center of the bolt head off. Once it's apart, you'll have another problem with putting it back together.
Don't cut the wires for any reason. While the connector(s) might not be salvageable, they disassemble quite easily and can be replaced without the need to rewire.
Helped a buddy replace his after a ID10t move on his part. I was able to stop him as he was about to reach for cutters. Saved a lot of time and headache.
Thanks,
Mike
Thanks,
Mike
Sounds normal to me. The bolt is held captive in the connector, as is the nut it threads into. Once the bolt is backed out of the nut it will stay there and spin and conveniently not get lost. Further loosening of the bolt will not "jack" the connector apart. Pry apart the 42 pin connector with a screwdriver or something. I think there's a tab to depress, not sure.
So, anybody (Tugly or otherwise) have a source for new connector shells for both sides of the 42 pin connector?
Maybe I'm just having a hard time visualizing this. How would you propose, exactly, getting the two halves separated while doing as little damage as possible?
Also, again, does anybody know if the connector shells are available as a replacement part?
When dirt and sand particles get between the two connectors, it acts like a cement. You could try soaking the connectors with a penetrating fluid. don't use a water based fluid, it could cause corrosion.
You may find corrosion in the actual wire pins and sleeves if you get them apart. If there is corrosion, it may contribute to the difficulty getting them apart.
Cutting the bolt head off will not make it easier to separate the connectors, since as you observed, the bolt is captive in the body side connector.
I don't know if new connectors are available, but there are devices called "separable connectors" that are used in industrial wiring installations to accomplish the same task of making connections while also allowing the circuits to be opened up for testing or isolating.
These separable connectors are not cheap, but they are probably not much more than a Ford part, if it were even available.
Tugly (Rich) or others with more recent experience with these devices could weigh in with their opinions as to a substitute, if there is no actual Ford factory part available.
Larry
Larry
http://www.ebay.com/itm/7-3L-Ford-42...ank Connectors
I do wonder about the quality a bit though.
So lets say I buy these replacement connectors. What is the process, and tools, needed to safely remove the wires from the existing shells and insert them into the new ones without damage, and without having to solder any new pins on?
Second - peel the backing off the connector, it's a silicone membrane that seals the wires. Once that's back as far as it will go, you can see inside the connector.
Using a jeweler's screwdriver (or was that a tiny needle-nose - I can't remember now), you can gently release the lock for each pin in there, and they just slide out. Leaving the old membrane on will keep the wiring order, if you can trust it to keep on sealing. Just make sure that you make note of how the old connector is keyed and approach the new one with the same orientation.
24 Carat
06-01-2016 06:09 PM
