AO injector
Old Oct 17, 2007 | 10:12 PM
c00nhunterjoe's Avatar
c00nhunterjoe
interesting to know, thanks. so to get the stage 2's you change the nozzle on the ac's to make them stage 2's?
Old Oct 17, 2007 | 10:24 PM
1997F-350's Avatar
1997F-350
yes some stage 2's are bigger than 160 though. typical size is 160-180 for 2's. but a new ac will be 160.
Old Oct 17, 2007 | 10:25 PM
c00nhunterjoe
which is better? i see most places are changing from the 180's to the 160's for 2's
Old Oct 17, 2007 | 10:28 PM
1997F-350's Avatar
1997F-350
180 will be more fuel. so that is more power that is better i guess.
im not a big fan of 2's with a stock turbo. never owned them just my .02 from many observations.
Old Oct 17, 2007 | 10:35 PM
shanett306's Avatar
shanett306
how many cc's are AD's and would they work in my 97 ? or would it me a worth while mod if I could find a cheap set?
kawa's Avatar
kawa
If you buy "New" stage 1's or 2 injectors do you still have to turn in your stock injectors or pay a core charge?
Roger
c00nhunterjoe
what is wrong with 2's on a stocker? not enough volume i assume?
Old Oct 18, 2007 | 07:53 AM
beansdiesel's Avatar
beansdiesel
Yes Stage 2's are 160's with nozzles, the nozzles can make about a 80hp differance. 180cc will strain a stock hpop too much and will make less power then a 160's in most cases.
AD's are about 140cc, they will swap in so if you get a real cheap set it could be worth it to you.
On New injs there is a 1200.00 core charge, its accually more then we do for the remans. This is because thats what we get charged when we buy the new ones, they really want the cores back.
Stage 2's will run on a stock charger just fine, most effecient no but I have many many customers running that with out problems and make very nice hp.
Old Oct 18, 2007 | 04:31 PM
Neal 97 250's Avatar
Neal 97 250
Will the SD pump support the 180's? Or do you need big oil?
Old Oct 18, 2007 | 05:19 PM
beansdiesel
SD pump is borderline, needs to be a good one.
Old Oct 18, 2007 | 05:29 PM
Neal 97 250
I got a reman from Ford on the shelf that should be good. I plan on big oil in the future. You got 180's?
Old Oct 18, 2007 | 08:52 PM
beansdiesel
Got what ever you want.
Old Oct 18, 2007 | 09:57 PM
  #28
Neal 97 250
That is the answer I wanted.
Old Oct 19, 2007 | 08:39 AM
  #29
caseydudem's Avatar
caseydudem
Question
Is the stealth DIY good enough? I seen you guys sell one for just under a thousand.
Old Oct 19, 2007 | 09:16 AM
  #30
tjbeggs's Avatar
tjbeggs
I think Bean meant if your running a single SD pump it needs to be a good one. For big oil even 2 15*'s are enough. The DIY stealth is just as good as the regular stealth assuming the pumps are in good shape.
tpc3
Dec 13, 2013 08:36 PM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
turbill
Dec 22, 2010 06:59 PM
SAltonS
Dec 18, 2009 08:36 PM
Nathan
Aug 5, 2001 08:58 PM
