Adding a Factory Posi Lock
Old Oct 17, 2006 | 04:38 PM
jboard's Avatar
jboard
Question Adding a Factory Posi Lock
My truck has an open rear and it sucks. Will a Factory posi fit into my truck with no problems? Are they good units, do they work like there suppose to?
This is Actual Pic and is this a Ford factory posi lock?
----------------Jeremy
Old Oct 17, 2006 | 04:43 PM
ForemanES's Avatar
ForemanES
I love my factory limited slip. It has been very durable and works well. Make sure to add the additives to your fluid.
Old Oct 17, 2006 | 05:30 PM
Cuda_jim's Avatar
Cuda_jim
You will need to buy new ring and pinion. The ring gears are different thicknesses IIRC
Old Oct 17, 2006 | 05:58 PM
jboard's Avatar
jboard
What is IIRC? I cant find a different ring and pinion other than the normal 3.55
Old Oct 17, 2006 | 07:19 PM
johnguc's Avatar
johnguc
There is an entire carrier you can put in the housing I changed mine last Fall.
Its awesome no more getting stuck in the middle of my gravel drive.
Old Oct 17, 2006 | 08:40 PM
jboard's Avatar
jboard
Where did u find your carrier...im looking for anything used and cheap so i dont have to use 4WD every time i drive in wet grass or a gravel hill.
-----------------Jeremy
Old Oct 17, 2006 | 09:10 PM
johnguc's Avatar
johnguc
http://www.accuautoparts.com/index.jsp
Got it from this company. I wouldnt say it was cheap I got all new parts and bearings.
Cost a little less than $1000.
But it was worth it I was constantly getting stuck.
Plus I had to replace most everything anyway since I had a bad pinion bearing that trashed the bearings.
Old Oct 17, 2006 | 09:19 PM
jboard's Avatar
jboard
Does anyone know where i can find a used diff parts like lockers. I think that at locker is goin to be my best bet.
-------------Jeremy
Old Oct 18, 2006 | 09:35 PM
racenitro's Avatar
racenitro
There were two on e-bay that went fairly cheap. One was the standard posi and the second was a more elaborate limited slip.
The unit you pictured is the standard posi. Clutches are behind the spider gears. SOme have an "S" spring in them. Search using sterling and 10.2.
Not to impessed with the standard unit. My heavy truck really needs the heavier unit. There are new ones listed also, over $1000 though.
Old Oct 18, 2006 | 09:37 PM
racenitro's Avatar
racenitro
Ford uses the 75 W140 synthetic without additives. Costs around $50.00 /gallon.
Old Oct 17, 2007 | 01:30 PM
caseydudem's Avatar
caseydudem
Can you explain more about this? I want to change mine too and I want to know what I'm getting into. You can just swap them with out replacing the ring and pinion? Thanks
Old Oct 17, 2007 | 01:57 PM
tjbeggs's Avatar
tjbeggs
I swapped a factory LS in and it was bolt in. The I just put new bearings in it and bolt my ring gear on and off I went. It needs clutches so I really don't like how it operates right now. by the time I put the bearings and clutch in I am half way to an Auburn unit. but as far as I know both the 10.5 and the 10.25 factory units are bolt in you just reuse your ring gear. you should really check the tooth pattern to make sure things are good there but mine was right on when I got it all back together.
Old Oct 17, 2007 | 02:19 PM
Cuda_jim's Avatar
Cuda_jim
That was a year ago, do you really expect me to remember what I was thinking JK
There are 2 thickness rings gears for after market carriers.
The ford LS and super duty LS is a bolt in like Tim said.
I just did the 3 pinion SD swap...love it. No more getting stuck on wet grass.
IIRC= If I Remember Correctly
Old Oct 17, 2007 | 02:42 PM
fuelman's Avatar
fuelman
c00n swapped in SD LS in with no problem just put old ring gear on and bolt in.I know a guy in missouri that has several most i think LS from FX4 trucks.I don't how much but he told me 500 for complete axle assembly.Pm me i have info at home.I plan on getting 2 for myself.
Old Oct 17, 2007 | 02:55 PM
jboard's Avatar
jboard
Well, since this is exactly one year ago since I posted this I bought a full locker from ebay since then. Lockright works great you just have to get use to it ratcheting around tight turns, and its a simple task to install it. No more slip for me locks up instantly because of being a full locker and its 100% to each wheel.
------------Jeremy
