Annual glo plug replacement!!!
Old Oct 16, 2007 | 10:18 AM
pmoon's Avatar
pmoon
Cool Annual glo plug replacement!!!
What is causing my glo plugs to fail in one year or less. Yes I have checked them with an ohm meter so it is not GP relay.
Old Oct 16, 2007 | 10:22 AM
ForemanES's Avatar
ForemanES
Do you use motorcrafts?
Old Oct 16, 2007 | 10:23 AM
ForemanES's Avatar
ForemanES
You said you checked the glow plugs with an ohm meter. What readings did you get?
pmoon's Avatar
pmoon
I don't know what brand the shop used
Old Oct 16, 2007 | 10:26 AM
pmoon's Avatar
pmoon
Ifinate resistance on most, two that are good read about three
Old Oct 16, 2007 | 10:28 AM
tjbeggs's Avatar
tjbeggs
They certainly shouldn't be going bad annually. I would guess they are not use motorcraft plugs. or the under valve cover harness is coming unplugged.
Old Oct 16, 2007 | 11:08 AM
Action4478's Avatar
Action4478
Definately check the wiring first.....
Old Oct 16, 2007 | 11:27 AM
jboard's Avatar
jboard
If they are not motorcraft brand they probably will go out annually...they are the only ones that will stand u to the abuse.
--------------Jeremy
Old Oct 16, 2007 | 12:19 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
and BTW NEVER buy AUTOLITE.
bubu89
Jul 22, 2012 03:16 AM
lowbed dud
13
Sep 6, 2008 08:37 AM
poooch
Dec 16, 2007 12:27 AM
URWorstNiteMare
Jan 24, 2004 03:45 PM
fordtrucksforever
Garage & Workshop
Feb 6, 2003 05:39 AM
