Old Feb 21, 2001 | 02:21 PM
nickc84's Avatar
nickc84
ok boys, i've got a question,
The 427-Side-Oiler, why is it so special? I got how they have the path on the left side of the block, my dad don't understand it neither do I and he has never even heard about it. I was wondeing if anyone could give my some info on it and how and why it is so special? And why its called the side-oiler?
Thanks,
Nick
"Speed equals money how fast do you want to go?"
Horsepower tv guy the fat one.
Old Feb 21, 2001 | 03:07 PM
dinosaurfan's Avatar
dinosaurfan
427
Nick, most FE Fords, and even some 427s, have a center, or top oil gallery, like most detroit V8s. These engines feed the oil to the cam bearings before anything else. When Ford was having durability issues with their nascar engines in the early sixties, they first added crossbolts to the block skirts, and then designed a new block with the main oil gallery down the side of the block, oiling the mains first, hence the sideoiler designation. They were made from 65 to 70 if memory serves me correctly. The one I've got is a 68 that has additional oil gallerys to allow the use of hydralic lifters, most 427s are setup for solids, some of them have the gallery for side oiling and hydralic lifters, but they aren't drilled. Ford sold blocks to industrial users, ChrisCraft marine, and lots of others, you never know what version you might see. Any 427 block is usually exspensive, but they are sought after because they allow you to build the biggest displacement FE. DF
Old Feb 23, 2001 | 09:42 AM
maggie11's Avatar
maggie11
The 427 side oiler was produced from '65 thru '67(maybe some in '68). It differs from all other FE's mainly because it oils the main bearings from a passage in the side of the block. Straight from the oilpump/filter to the mains. All other FE's oil the mains through the upper center oil galley and it comes down through the cam bearings 1st. Before the mains can oil, the cam has to oil. Kinda backwards from what seems to me to make good common sense. If you can find a diagram showing the oil flow of each, it becomes very clear why the side oiler is so well known and in such demand.
Old Feb 23, 2001 | 06:20 PM
nickc84's Avatar
nickc84
thanks guys, i appreciate the responses. And if anyone could ever get a nice pic of the block or a complete 427 it would be appreciated. thanks guys.
Nick
FE427TP's Avatar
FE427TP
427
[font size="1" color="#FF0000"]LAST EDITED ON 23-Feb-01 AT 07:33 PM (EST)[/font][p]>designed a new block
To say a sideoiler oils the mains first is kind of misleading. Check out the oil paths @
[link:members.nbci.com/brat360/FE_oiling1.jpg|FE oiling pic] This shows the different oil passages (top left for sideoiler) and where to plug to run solid lifters. I guess a more accurate description is the sideoiler dumps the oil between the main and cam bearings so it can flow to the mains without having to squeeze by the cam bearings. The flow would go easier to the cam bearings than having to turn back to the mains. In any case it's a vast improvement over the top oiler unless you can cute the grooves behind the cam bearings bigger.
Old Feb 25, 2001 | 04:52 PM
hemi's Avatar
hemi
the side oiler can be easily identified from outside the block by the three small screw in plugs just above the crossbolts on the left side of the block.
Old Mar 2, 2001 | 11:51 PM
fordmann's Avatar
fordmann
427
I've been told my intake manifold came off a 427 PI. How can you tell? It is a factory FORD aluminum manifold. It is a 66 ( C6AE-9425-H. I know all the numbers and letters except the letter "H". Anybody know what it means? TIA No it's not for sale!!
Old Mar 3, 2001 | 09:20 AM
fordmann's Avatar
fordmann
427
jaywischmann
20
May 19, 2013 04:46 PM
Red460
16
Mar 1, 2006 10:29 PM
actioncam1
Dec 8, 2005 04:53 PM
Annihilator
Jan 20, 2005 04:51 AM
Shomeyrwit
Feb 20, 2003 09:10 AM
