427 intake?
Old Mar 3, 2001 | 12:01 AM
fordmann's Avatar
fordmann
427 intake?
I have a factory FORD aluminum intake. C6AE-9425-H What does the "H" stand for? No it's not for sale!! I've been told it came off a 427 PI. Anybody have a clue? TIA
Old Mar 3, 2001 | 12:35 AM
BB's Avatar
BB
427 intake?
[font size="1" color="#FF0000"]LAST EDITED ON 03-Mar-01 AT 01:42 AM (EST)[/font][p]That's the aluminum manifold for the 428 PI. This is the manifold that the 428CJ iron manifold was patterned from. After the CJ was into production, the '69 and '70 PI got the iron manifold too.
Barry
P.S. I've not heard of a 427 in a PI version.
Old Mar 3, 2001 | 12:47 AM
fordmann's Avatar
fordmann
427 intake?
Thanks. I bought a motor on e-bay about a month ago. It is a 3904V 73TE bored .030, larger valves etc. He told me he put a 305 comp cam in it. I think thats a little to much for what I'm going to use this for. It's going in a 59 panel truck with original 59 F250 4x4 running gear. What do you think? I was thinking of a stock 428cj cam with this intake. TIA
Old Mar 3, 2001 | 07:14 AM
karljay's Avatar
karljay
427 intake?
The stock 428 cam is an OK choice, but I'd get a newer designed dual pattern one from Crower or Crane. Most seem to like the 268H but I went with the Crower Beast 292H, the range is 1300~3800 redline of 5300+ and gives great low-mid range torque. One guy tried several and said the Crower made the best power, but it really depends on the overall engine build.
Old Mar 3, 2001 | 08:15 AM
dinosaurfan's Avatar
dinosaurfan
427 intake?
Mike, I'll have to agree that the cam sounds a little big. Also aren't most of comps cams a single pattern? I think the FEs usually like dual pattern cams, I have one from Crane and one from CamDynamics. What trans are you going to run and what axle gears do you have? That will make a big difference. DF
Old Mar 3, 2001 | 09:20 AM
fordmann's Avatar
fordmann
427 intake?
I've switched from the factory 4spd to the light duty clark 5spd. I'll still have a granny low plus a 5th overdrive. The gears are stock for now at 4.56. When I get it all together it will be a semi daily driver. I'm trying to have it ready for P.F. I've been leaning toward a set of 35" tires. I don't need this thing to be to tall. The truck will be built inside and out using pure FORD parts. Thanks for all the help guys. It is greatly appreciated.
99 explorer XLT 302 AWD 96 F150SC XLT 4x4 302
76 F150 LB 4x4 390-4V 75 F250 LB 4x4 "highboy" 360-2V
60 F100 2wd parts two 59 panels one is for parts
58 F100 Cus.cab 73 429 58 F100 67 289 w/66 4v heads/int.
59 F250 4x4 frame/running gear 3 FORD riding mowers
a FORD dsl. tractor FOR/New Holland hay equip.
and a dog named Bronco!
Old Mar 3, 2001 | 05:57 PM
FE427TP's Avatar
FE427TP
427 intake?
stromburg
Nov 17, 2012 11:10 AM
STGFordCrazy04
40
Nov 16, 2007 05:10 PM
jazzy66
Feb 28, 2005 07:20 PM
padd54
May 31, 2004 07:15 AM
n8ster
Sep 8, 2003 11:10 AM
