ole 86
Old Oct 13, 2007 | 04:38 PM
macm's Avatar
macm
ole 86
Newbie here.Well,I found the fuel relay,it was bad, bought new, installed, pumps hum. How hard is it to test the pressure of the fuel rail? Do I do it at the tire valve looking thing or what? Oh, 86 f 150 EFI 5.0.
Old Oct 13, 2007 | 07:43 PM
beaners1's Avatar
beaners1
Yes the schrader valve is where you test the fuel pressure but a tire pressure guage does not work, you need a fuel pressure tester.
Old Oct 14, 2007 | 06:35 AM
macm's Avatar
macm
ole 86
That's what I thought. I just saw the schrader valve and didin't know what it was called. So, Does anyone know if Auto Zone has a fuel pressure tester?
Old Oct 14, 2007 | 10:36 AM
macm's Avatar
macm
ole 86
Well, I think I've narrowed it down to maybe the fuel pressure regulator, if that's what's mounted on the fuel rail on drivers side, towards the fire wall. Now I need to find out how to check. When I relieve the pressure at the schrader valve it's air, but it's under pressure. I'm thinking I'm not getting fire to the intank pump. Anybody???
Old Oct 14, 2007 | 06:38 PM
302 F-150's Avatar
302 F-150
Pull the vacuum line off the regaulator and if there is gas in it your regualtor is bad
Old Oct 15, 2007 | 04:57 PM
macm's Avatar
macm
ole 86
There was no gas from the vacuum line to the regulator. Need to find out if I have power to in tank pump. I guess lay under tank when ignition is turned on to see? I have a test light, anything I can check for power with it?
Old Oct 17, 2007 | 12:02 PM
302RP's Avatar
302RP
The tank has a connector going to it with four wires, pull back the sleeving and you will see a red wire (hot) orange wire (ground from actual pump) black wire (chassis ground) and last wire I think was blue w/yellow (fuel gage wire). Shave off some of the insulation from the red wire and check if you have power with your test light or you can run a ground wire and hot wire from your battery to see if pump is good and actually kicks on or not. remember red is hot and orange is ground. good luck!
Old Oct 17, 2007 | 05:02 PM
macm's Avatar
macm
ole 86
I do have power to both pumps,disconnected fuel line at fuel rail(supply),not return, nothing comes out. Did the same at the pressure pump, on the frame, nothing. I wonder if I have enough fuel in the tank, put in 4.5 gal. or so. I thought that would be enough. Might not be.
jacobjacob86
Bronco II
Oct 27, 2011 10:12 PM
Dev
Dec 29, 2009 07:05 AM
fairfield86f150
Aug 1, 2007 11:29 AM
Dustin_86
Dec 8, 2004 10:33 PM
allford86
Nov 16, 2004 07:51 PM
