86 ford fuel injectors
Old Nov 14, 2004 | 07:50 PM
allford86's Avatar
allford86
ford fuel injector voltage
Old Nov 15, 2004 | 04:07 PM
allford86's Avatar
allford86
Injector Wire Voltage
What is the voltage on an 86 injector wire and are both suppose to be hot when the key is on
Old Nov 16, 2004 | 07:51 PM
locknkey's Avatar
locknkey
The ohm resistance on an 86 Ford is 16.2 checked with a multimeter. There is differences however as the Bosch are stated to be 14.0 ohms (part #0 280 150 710 )
Then you have different colors of the FORD (Bosch) Injectors (part # E5TE-9F593-AA) Gold Color which is 16.2 ohms
part # E5TE-9F593-AB is also gold color is 2.35 ohms
And then theres another thats a FORD (Nippon Denso) (part # -9F 593-A2A) Which is a green color and is 2.0 ohms for year models 1986
Then theres the Gray color (part # E59E-9F593-AB) which is 16.2 ohms
So all in all it really depends on WHICH PART you have and the color of it, AND the brand.
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
daw00l
Sep 9, 2009 11:20 PM
motorhead_83
Dec 8, 2004 11:41 PM
benschultz4x4
1978 - 1996 Big Bronco
Mar 7, 2004 11:17 PM
