E40d
Old Oct 13, 2007 | 02:41 PM
bryonbaccus's Avatar
bryonbaccus
Question E40d
mabe some usefull advise on shift problem. original problem:trans seemed to be hunting in and out at certain rpm. was told to replace torque converter. i did. then overdrive went out. had tranny shop in town rebuild nowsix months later,will not move in overdrive. have to take out of overdrive to get moving then put back in overdrive when truck is in motion, then all seems good. local tranny guythat rebuilt cannot seem to fix promlem after replacing all sensors and solenoid pack again!!
Old Oct 15, 2007 | 11:12 AM
mrknight01's Avatar
mrknight01
Explorers, Sport Trac, Mountaineers & Aviators don’t have E4OD’s.
After looking at your profile I see you talking about your 93 F350.
Originally Posted by bryonbaccus
mabe some usefull advise on shift problem. original problem: trans seemed to be hunting in and out at certain rpm.
The first problem you list sounds like a dirty speed sensor in your differential might be dirty. You can pull it out and clean it this would also be a good time to service your differential to. A bad PRNDL(manual laver position) sensor. Will also cause this when they get warm. The fix for that is replace it.
what do you mean “will not move” does it fill like it’s in neutral or like it’s in 4<SUP>th</SUP> and you need to down shift to a lower gear? And once your moving is it shifting?
Old Oct 15, 2007 | 06:21 PM
bryonbaccus
thanks for the reply,all sensors have been replaced to include:mlp,speedo-sensor, tps,and solenioid pack again! all by trans shop in town. nothing fixed prob. as far as woun't move at all, meaning it feels like it wants to go,but will not move until shift out of overdrive is selected by the button on the shifter.
Old Oct 16, 2007 | 12:04 AM
mrknight01's Avatar
mrknight01
Well the only thing that changes in the trans when you turn the overdrive off is the coast clutch comes. That is before 95. The main input for the trans is the input clutch it’s a one-way sprag. Then when you turn O.D. off the coast clutch is on for more strength .
I hate to say it but it I think you need to find a better shop. One that is honest with a good reputation. I worked in trans shops for 14yrs auto shops for a few more and there are some bad one and some very bad ones. Look for a ATRA shop in your area and then ask ATRA which one they recommend. Here if their link http://atra.com/
sorry you had to find one of the bad ones.
Maybe you will be lucky and they might want to save there rep. and fix it right under warranty.
Just remember there are still good mechanics and shops out there. You just have to ask around.
BossTweed
Jul 2, 2013 11:27 AM
Rtpjunior
Feb 15, 2003 06:25 PM
Mike Davis
Jul 9, 2002 09:19 AM
lairdramsay
Dec 5, 2001 09:31 PM
northey
Oct 30, 2001 07:36 PM
