Oil & Lubrication
Engine Sludge cleaner
Old Oct 11, 2007 | 07:08 AM
newfordguy77's Avatar
newfordguy77
Does any1 know of a good engine flush treatment type of stuff. Something that some1 on here has used before with success and no harm done to the engine
Old Oct 11, 2007 | 07:41 AM
saftman's Avatar
saftman
Auto-RX. Look on their web site.
Old Oct 11, 2007 | 10:56 AM
jimandmandy's Avatar
jimandmandy
Second that. ARX is expensive, but I have used it and it works without harm.
Jim
Old Oct 11, 2007 | 11:08 AM
TallPaul's Avatar
TallPaul
AutoRX? Where am I, at the oil guy site? Oh well, maybe it works as well as any other method, I don't know.
I would run about 12 ounces of Schaeffer's Neutra 131 in the oil for a whole OCI.
Old Oct 11, 2007 | 12:28 PM
Melchiah's Avatar
Melchiah
just drop a quart of tranny fluid in for a couple days and drive it regular thats always worked for me and my engines are squeeky clean
Old Oct 11, 2007 | 12:36 PM
rsylvstr's Avatar
rsylvstr
Jim
same here.... http://www.auto-rx.com/
Old Oct 11, 2007 | 02:46 PM
dragogt's Avatar
dragogt
Ill run a qt of diesel/kerosene for about 5 min, before the first oil change on a it's new to me car/truck.
Old Oct 11, 2007 | 05:52 PM
SixPak's Avatar
SixPak
I've heard nothing but good things regarding auto-rx, however I've not personally used it.
here is a site with the test results:
http://www.auto-rx.com/rms13/
also, a rather lengthy discussion on oil additives can be followed here on an oil forum:
http://theoildrop.server101.com/foru...t=0&Board=UBB5
Personally, I usually just dump a quart of trans fluid in my crankcase a day or so before I plan to do an oil change. Trans fluid is loaded with detergents and does a pretty good job of keeping an engine clean.
(it should be noted that auto trans fluid is basically a 5-7 wt oil loaded with detergents and anti foaming agents, along with some other stuff. I've been doing this with all my vehicles regularly for 30 years and never had a negative result.)
Old Oct 11, 2007 | 11:29 PM
Sport45's Avatar
Sport45
Why do you want to flush it?
If there's a lot of sludge or carbon in an engine I'd just as soon have it stay put and not break off in chunks. I just maintain my regular oil change interval. If an engine needs to be cleaned I'll take it apart and see to it that all the bad stuff is removed and not just moved around. I've taken apart engines that had A LOT of coke/carbon in them. Other than the brushing, scraping, and picking to get it out I couln't see where it did any harm.
Old Oct 12, 2007 | 04:35 AM
PW01's Avatar
PW01
Another vote for Auto Rx
Old Oct 12, 2007 | 11:23 AM
rsylvstr's Avatar
rsylvstr
that's the great thing about ARX, according to many real world uses (along with research of course), it slowly breaks it up, not in chunks like a flush.
I've used it on 3 vechicles and notice very very tiny bits of (possible) sludge on my dipstick....and then i drain it away.
Mil1ion
Mar 26, 2002 08:32 AM
redranger1
Mar 12, 2002 10:45 PM
dfisher1
Dec 20, 2001 02:55 PM
Mil1ion
Nov 10, 2001 09:53 PM
Tom1.0
Oct 16, 1999 12:14 AM
