Oil & Lubrication
SeaFoam?
Old Oct 13, 2007 | 06:37 AM
ctvanover's Avatar
ctvanover
Question SeaFoam?
I have an '85 F-150 302 4WD 5-speed. A buddy of mine told me about using this stuff called Seafoam to kind of help clean out my engine. Does anybody know or have heard of this. I don't want to use something that will hurt it. Oh by thee way the 302 has a fresh rebuild and it's only a couple of years old but it really hasn't been used that much either.
Old Oct 13, 2007 | 09:06 AM
ubereal2's Avatar
ubereal2
I used SeaFoam once. It does a good job of cleaning, but it also killed an ailing motor.
Old Oct 13, 2007 | 12:55 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Just think all that sludge broken loose grinding up the inside of your motor. Add some to the gas as well suck it into the intake as muffler shops like replacing cats.
Old Oct 13, 2007 | 01:10 PM
blue beast's Avatar
blue beast
Run some synthetic or diesel oil the extra detergents in it will clean more gently then those products that basically rip it out!! Just clean your oil when you should for your conditions, And do it on a regular schedule. Have you pulled a valve cover to check if the motor even needs a cleaning?
Old Oct 13, 2007 | 03:03 PM
"Beemer Nut"
Almost as clean as a fresh rebuild at 276K miles inside over here.
Jason302
Feb 22, 2025 11:04 PM
JackWStafford
Nov 5, 2016 05:08 PM
mblayton
1978 - 1996 Big Bronco
Oct 7, 2011 11:08 PM
rlay302
30
Jun 15, 2011 08:05 PM
hwknsdrag
17
Mar 7, 2011 04:24 PM
