I'm new to the diesel and working with a dealer that is difficult. I know they changed the paramaters for the boost as my diesel (not ford) mechanic checked it out. Becuase I'm not mechanically inclined it was explained to me that the boost is set for power right now rather than mileage. The dealer changed it back in May and won't acknowledge they did it but that's when my MPG dropped significantly, I know they did it, and they "know" they did it too. As soon as I get the write up from my NON Ford Motor Co mechanic I'll take it to them and ask for it to be brought back to the original stock specs. That should give me the MPG economy I'm looking for. Since I drive it every day I'd rather see the fuel economy rather than a big boost from the turbo every time I press the accelarator.
In may they checked the boost and also worked on the fuel gauge that was working improperly.
I'm also going through Ford Motor co as I couldn't get anywhere with the dealer. Until I did the mileage comparison from tank to tank I thought the fuel gauge was still off but not I think my truck is just burning more fuel.
I think the big sign on they posted on my forehead was the problem "She's a woman and doesn't know sh*&" was the overall problem. This dealership is the worst I've dealt with.
I have no idea what you mean as the Ford dealer took away you mileage and made it boost more for power when compared to economy.. I am a tech and we only flash for driveability concerns and when Ford has a TSB,SSM or is required for an update.. There is no dealer flash that would change your boost or mileage on you on purpose athough some owners say they see a slight difference. I have ran 3 different ford flashes in my own truck and other guys that work w/ me and see no changes in either of your complaints on our own trucks. Only way to do that is w/ an aftermarket flash tool like the SCT. if you would like more mileage give Matt @ Spartan a call and he can set you up w/ an SCT and an economy tune.
I know my post is very generic...I'll post more info on Monday when I get the specs. From what I understand the tubo is kicking in way too soon.
then it is starting to stick and may have DTC'S in the PCM and should be diagnsoed by your dealer if you are still under warranty. They cannot change the settings to make it spool earlier in the RPM range unless they used aftermarket equipment which will not be the case.
this is what the mechanic told me:
"Turbo boost & engine tourqe values early & high on overdrive lockout, advised customer to call fords service for reflash to factory updates and specs"
I called Ford and this place is especially difficult to deal with, he said he'd recheck it out but doesn't think there is anything wrong with the truck. I guess the fact that I was getting about 18mpg before they "fixed" my truck and am only getting about 12/13 now is just a figment of my imagination.
basically the mechanic told me they set it for a power mode rather than the factory specs that have a more economical mode for fuel consumption. The dealer acknowledges they reprogrammed the pcm but not that would have such an effect as I've stated. I'm very aggravated and obviously not mechanically inclined so I feel patronized.
the dealer cannot change the flash that ford gives them and every truck w/ the same PCM stratedy gets that exact same flash file.The tech cannot give you a power flash and take away your older enonomy flash because there is no such thing from ford. I understand your frustration but the dealer only did what they were supposed to do. I have flashed many vehicles and never heard of any mileage concerns like you have, there has to be another concern.
thanks for the post, I just found that out from another dealer whom I'll be using now. I'm on the phone with Ford as well. You're right, something else has to be going wrong conincidently around the same time they did the reprogramming that has pulled down the mpg.
I really do like this truck but feel with the issues I'm having it may have not been the best choice.
I pull a 6k horse trailer with it and plan to get a much bigger trailer next year and am concerned that this truck will really have fuel economy issues with it if this isn't resolved.
I may just put it in a different reputable shop to have them check it over and see what they think.
My Pyrometer reads at idol 400-450, at 65 mph 700-800. I have no chip or programmer. Boost is 0-5psi, peaks 10psi under slight load. I get 15-17mpg highway. Everything sounds normal from what I have been reading in this thread. When I had my truck reflashed at the dealer I had lower MPG. I disconected the battery and let the truck re-learn. I got getter MPG. Just a thought...
Forgive my stupid question but would i have to disconnect BOTH batteries and will that negatively impact my remote start/alarm. I'm willing to try it as it seems I am stuck. Husband wants me to trade it in on a dodge/cummins before anything earth shattering happens but I'm not ready to do that yet.
It shouldn't have any negative affect on your remote start. Disconnect BOTH batteries--negative cables first, then positive. Turn your headlamp switch on for 10 minutes then turn it off. Reconnect your batteries positive cable's first. Give it at least 5 cold restarts to relearn then run a mileage test. If it's not better after that, return to the dealer with your concerns.
There are three small capacitors in the Keep Alive Memory (KAM) that need to be discharged. Turning on the headlight switch helps complete that process quicker, that's all.
The dealer needs to fix the problem at hand, high pressure oil pump fitting.....they know all about it. Common for a 2005, no start condition when warm, starts when cold. Cat has nothing to do with it......walk softly but carry a big hammer
