oil overfill? stupid question I know..
I changed my oil today, all went fine except when I started putting in oil, the dipstick never really started to show the level. So I ended up putting in 16qts and then I got scared and stopped adding oil. The dipstick never seemed to register any oil. Perhaps the truck was a bit unlevel? So tonight I went and put the truck on a level place, and here is my dipstick (see picture). Did I overfill? Now what should I do? I did notice some oil on the frame/tranny pan before I changed the oil. Perhaps I overfilled last time too..? does the engine spew oil mist underneath if you overfill?
If it is too much, then is there a simple way to drain just a bit?
Here is a picture of the dipstick:
That's one of the nice things about having a Fumoto valve, a little overfill like that and it's not messy to drain a little oil. I saw a thread a while back about a debate on the effects on the 6L when too much oil is added. I'll try to find the thread and hopefully somebody will chime in.
But honestly, if you're going to be changing your oil, get yourself a fumoto valve and you won't regret it!
I had to drain some from mine once and I just put a measured container inside of an oil drain pan, pulled the plug and watched it drain until I had removed what I wanted and then stuck the plug back in. It was really a lot more controllable than I had anticipated. A rubber glove helps. After that I decided to get a Fumoto valve.
Thanks, this is what happens sometimes when you DIY I guess. But I would rather still do it myself because I have zero confidence the dealer would do any better. It sounds like they screw this kind of stuff up all the time. I will get it fixed, and then I will be self-sufficient. It's a good lesson in being detail oriented. ;-).
What I like about adding 14 quarts is that the final level is just a little below the word "max" in the checkered portion of the plastic on the dipstick. I can see it a lot better at this level and therefore if it ever drops, I know I have some oil loss somewhere. If I were to add more than 14 quarts on my truck, I would have trouble seeing where the actual level was. Since there have been threads on concerns over foaming when overfilled, I just felt better when I could know what the level really was after an oil change.
ryansalay
1999 to 2016 Super Duty
45
01-10-2018 06:55 AM
rob_jones
08-09-2015 01:11 AM
jwt27ta6
51
10-10-2014 09:35 AM
Piginabag
04-24-2010 07:52 PM
60, 60l, 73, crankcase, diesel, engine, f150, f250, fill, ford, oil, overfill, overfilled, overfilling, powerstroke
