What mods first
Old Oct 7, 2007 | 01:45 PM
blrman1962's Avatar
blrman1962
Question What mods first
I want to start doing the mods and need to know where to start first I tow a 13000 lbs fifth wheel and have an early 99 w/373 gears I want to get the DP tuner chip I will ask Jody what to get for settings Should I get gauges first? or can I get the chip without the gauges I will be getting a new exhast system in the next few months I think it will be the 4" I just need to know where to start Thanks
Old Oct 7, 2007 | 02:24 PM
powerstrokinsmokin's Avatar
powerstrokinsmokin
Ihave the same truck, start with boost, pyro and trans temp gauges. get intake and valvebody for trans. Tell jody when you get your dp tuner about the valve bosy and get a v-10 trans cooler or the 6.0 trans cooler. that would be a great start up and you can work from there. Also from what i've heard you can have Jody retune the chip for additional mads as you go so the is a great choice.
Old Oct 7, 2007 | 03:25 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
check this out-
https://www.ford-trucks.com/forums/5...confusion.html
Old Oct 7, 2007 | 03:28 PM
JLDickmon's Avatar
JLDickmon
1. Gauges
2. Exhaust
3. Intake
4. Transmission
5. Tuner/chip
Old Oct 7, 2007 | 03:34 PM
gogoman's Avatar
gogoman
FTE Sponsor
I routinely recommend gauges, air intake, exhaust and chip, in that order. Clearly, this is totally up to the customer.
Your gauges will let you know what is going on under the hood and out the back. When your towing, this info is helpful.
The air intake and exhaust allow your truck to inhale/exhale, and just like us, it performs much better when it can breathe. Performance and fuel economy are usually improved with these additions.
Lastly, the chip can provide some additional "oomph" and changes to shift points to help get up some of those hills. A few customers with '99s opt for new turbos instead of chips...to each his own.
Hope this helps!
Old Oct 7, 2007 | 05:34 PM
95Z71's Avatar
95Z71
What kind of intake do yall recommend?
Old Oct 7, 2007 | 05:39 PM
John311t's Avatar
John311t
6637 hands down. 30$ at fleetfilter.com. That and a piece of 4" pipe a few inchs long and your in business.
Old Oct 7, 2007 | 06:25 PM
blrman1962's Avatar
blrman1962
Thanks for all the advise I bought the 6637 filter and now I am tring to get a piece of pipe the local muffler wants 40.00 for 1 foot piece I am sure I can find it cheaper
Old Oct 7, 2007 | 07:04 PM
PowerstrokeJunkie
I didn't use ANY pipe.
Old Oct 7, 2007 | 07:12 PM
RogueSpear2023's Avatar
RogueSpear2023
Ask the local exhaust shops to give you a piece off their floor, if your going to be putting exhaust on soon, go to the shop when you get it done and get one of the scrap pieces. The piece of pipe only needs to be about 3 1/3-4 inches. Otherwise some people have used PVC with and outside diameter of 4 inches as well. You may want to get two pieces 4 inches long incase you want to do the CCV mod later. Most exhaust shops have all kinds of 4" exhaust pieces laying on the floor. Otherwise go dig in their dumpster out back.
Old Oct 7, 2007 | 07:18 PM
95Z71's Avatar
95Z71
When you do the 6637, do you have to it any, or you just stick it right in?
And the pipe your talking about, is that for the intake? Anyone got pics of this?
Old Oct 7, 2007 | 07:47 PM
PowerstrokeJunkie
I did not use any pipe for the filter-tube connection but i did use a piece of pipe for the part that replaces the CCV tube.
Old Oct 7, 2007 | 07:54 PM
95Z71's Avatar
95Z71
wow that's a beauty
Old Oct 7, 2007 | 09:44 PM
PowerstrokeJunkie
There's going to be alot more red under there in a few weeks.
Old Oct 8, 2007 | 03:06 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
You should start with a cold air intake: http://motorhaven.autoanything.com/air-intakes/20A50096A1.aspxor an aftermarket exhaust: http://motorhaven.autoanything.com/exhausts-mufflers/10A50209.aspx
jamesbaughman333
15
Dec 1, 2010 01:29 PM
grizzly11
18
Apr 21, 2010 08:59 PM
weekendwarriorfsw32
18
Apr 6, 2008 08:08 PM
jrciii56
16
Mar 16, 2006 08:31 AM
oppy
Computer Chips & Tuners
May 19, 2003 11:06 PM
