Best Programmer and Chip Combo?
Old Mar 15, 2006 | 09:32 AM
jrciii56's Avatar
jrciii56
I have and 2000 F350. I need advice on the best chips and programmers on the market. I need know what companies to work with and not to work with. I want HP without buring up the tranny. I will be putting gauges, 6637 air filter mod, and 5in exhaust on the truck. I am looking to gain 50 to 150 hp.
Old Mar 15, 2006 | 09:36 AM
TXsnyper's Avatar
TXsnyper
I'll say before everyone else does. Go with the Jody Tipton flip chip. It is supposed to be the best. I am saving my money for one right now.
You may also want to do the AIH delete and the HPX line. My $.02
Old Mar 15, 2006 | 10:05 AM
jrciii56's Avatar
jrciii56
How much does it cost? Where can I get one? What kind of hp gains can I expect?
Old Mar 15, 2006 | 10:06 AM
jrciii56's Avatar
jrciii56
Also what is a AIH delete and the HPX line?
Old Mar 15, 2006 | 11:00 AM
powerstroker27's Avatar
powerstroker27
If I'm remembering corectly it can range from $240 to $465, or something like that, depending on how many positions you want and the setting to choose from are stock, no-start, valet, high idle, (20, 40, 60) tow, 80 econo, 100 performance, 120 race, 140 extreme, and of course if you need it then you can get yours custom tuned.
The AIH is the Air Induction Heater which unless you live up north and dont have a block warmer then you dont need and it is just blocking about 20% of the air flow thats going into your engine. It really cheap and easy to get rid of and you can find the plugs for it in some of the sponsors sites. The HPX is the High Pressure oil Crossover which will make the pressure to the injectors more balanced an thus give you a smoother running engine.
Old Mar 15, 2006 | 11:28 AM
aklim's Avatar
aklim
I don't see the issue with the AIH delete. It operates when the engine is running and the ambient temp is below 32 and the oil is below 55 and the tranny is in park with the glow plugs off. What that means is that you start the truck and leave it in idle and it is cold out there and the GPs have cycled off. Well, most times when I take start it, I take off soon after gently. That is why I used it as a boost gauge tap.
Old Mar 15, 2006 | 12:09 PM
jrciii56's Avatar
jrciii56
Is the the name of the chip Jody Tipton or another name? I am having trouble find these chips on the net
Old Mar 15, 2006 | 12:14 PM
SpringerPop's Avatar
SpringerPop
Use Google. Search for Jody Tipton.
It's the absolute first hit.
Pop
Old Mar 15, 2006 | 12:16 PM
jtharvey's Avatar
jtharvey
Go to www.dp-tuner.com. That's Jody's website. Also, no matter what you do, some tranny upgrades are suggested. The stock engine can destroy a tranny without any mods. A BTS valve body would be good for the trans.
Old Mar 15, 2006 | 12:18 PM
hink10's Avatar
hink10
Here is a link:
http://www.dp-tuner.com/
Not too much info on the site, give him a call with questions. He will recommend a BTS valve body for the transmission, it allows him to use a different shift program. Definitely worth the $225 for the BTS, shifting and TC lock up are MUCH improved. Get one of Jody's chips, you won't be dissapointed. They have very good power and still keep EGT's in check.
edit: JT, ya beat me to it! I need to improve my typing skills!
Old Mar 15, 2006 | 12:41 PM
jrciii56's Avatar
jrciii56
Got it! Thanks. How hard is it to change the valve body is it something a normal person can put in?
Old Mar 15, 2006 | 12:44 PM
hink10's Avatar
hink10
It's pretty easy, basically just unbolt the old and put in the new one in. If you go that route, let us know and we can give you detailed instruction.
Old Mar 15, 2006 | 12:46 PM
jrciii56's Avatar
jrciii56
How about the ATS torque converter?
Old Mar 15, 2006 | 03:27 PM
jtharvey's Avatar
jtharvey
The ATS is a goot TQ. I think Brian (don't quote me on this) put the 5 plate TQ in when he does your trans. That and a valve body will help your trans a lot.
Old Mar 16, 2006 | 08:23 AM
jrciii56's Avatar
jrciii56
Okay, I have to admit I am new to this forum. Who is Brian?
