Shocks
Old Oct 11, 2007 | 12:40 PM
7.3L DID TD's Avatar
7.3L DID TD
Originally Posted by DCSpecial
They ride good....better than the Bilstein 7100s I ran before. I run duals.
Reservoirs are just for looks unless you beat the snot out of the truck. You can get the same ride out of the mono tube DRs.
DC Special, I've just returned from your gallery and well sir, YOU WIN. That's the worst case of PMS I have ever seen.
Old Oct 11, 2007 | 05:57 PM
DCSpecial's Avatar
DCSpecial
Which gallery here on FTE or on Truckblog?
And yeah, I do have an illness and have done and redone many mods.
Now I've started on the 07, but it won't be as heavily modded as my 01....it's my work truck.
Old Oct 12, 2007 | 12:13 PM
zstyle01's Avatar
zstyle01
For the DR monotube shocks, i read they were made for 3-6 lift and 8-12 so i buy 4 shocks for a 4" lift will the front and rear be interchangable or will i have to specify when ordering?
Old Oct 12, 2007 | 06:52 PM
DCSpecial's Avatar
DCSpecial
If you tell the shop you order from that you have a 4" suspension lift, they *should* know what shocks you need.
Monotubes for a 99-04 SD with 3-6" of lift:
fronts are p/n: 3-7500
rears are p/n: 3-7501
TJK1
Apr 11, 2013 08:32 PM
jimford1
1978 - 1996 Big Bronco
Nov 25, 2009 02:53 PM
busdriver47
Oct 13, 2008 09:17 AM
hookup66
Dec 28, 2005 10:55 PM
