Shocks
Old Oct 6, 2007 | 04:25 PM
anotherfordguy's Avatar
anotherfordguy
Shocks
Is any one running Donahoe shocks?
I need a new set and looking at their new shocks possibly the remote reservoir shocks since i spend a good bit of time off road.
I would like to get a shock that doesnt rust in a few years like all the other ones I had.
Old Oct 6, 2007 | 08:11 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Don't know about the shocks, but I will bump this thread.
Good luck.
Old Oct 6, 2007 | 09:12 PM
cangim's Avatar
cangim
I don't know about the shocks either, but I know what you mean about them starting to rust. I repainted mine with a rattle can not too long ago.
Old Oct 9, 2007 | 01:51 PM
Overkill's Avatar
Overkill
FTE *******
We have extensive experience with these shocks and I believe you will be very happy with this choice. The DR shocks were developed specifically for use on SDs and feature a digressive piston design which provides outstanding ride quality. The shock bodies are silver zinc plated and clear powder coated to insure a long lasting luster. The shocks are also backed by a lifetime warranty. Let me know if you have any more specific questions.
Old Oct 9, 2007 | 05:42 PM
DCSpecial's Avatar
DCSpecial
I run the DR reservoirs on my truck.
The finish on them kicks azz.
Old Oct 9, 2007 | 06:15 PM
empiretc's Avatar
empiretc
Is there a set available for my 2wd?
Old Oct 9, 2007 | 06:18 PM
DCSpecial's Avatar
DCSpecial
Nope, nothing for a 2wd.
Old Oct 9, 2007 | 09:50 PM
Donny_D's Avatar
Donny_D
hey Overkill was lookin at the shocks on the website on the pic, was lookin at the duel shock mounting hoop, says that you need to have the DH 6 or 8" leaf spring lift, i have 6" leafs upfront from an unknown company to me there is no sticker or marking on them to tell me what company... was just wonderin if that was true or just a way for them to see more lifts? also is there a way for me to know how big of a shock i will need to replace the ones for the lift should i just measure them and see or is there some chart of sizes this is my first lifted truck and am curious thanks
Old Oct 10, 2007 | 01:23 PM
anotherfordguy
DC Special
So the reservoir shocks are worth the money? How is the ride?
Old Oct 10, 2007 | 01:36 PM
DCSpecial's Avatar
DCSpecial
DC Special
They ride good....better than the Bilstein 7100s I ran before. I run duals.
Reservoirs are just for looks unless you beat the snot out of the truck. You can get the same ride out of the mono tube DRs.
Old Oct 10, 2007 | 01:42 PM
anotherfordguy
is the price still around 200 for them?
Old Oct 10, 2007 | 02:02 PM
DCSpecial's Avatar
DCSpecial
Yes, it is....
Old Oct 10, 2007 | 02:08 PM
empiretc's Avatar
empiretc
Just another reason my next truck will be a 4x4.
Old Oct 10, 2007 | 07:14 PM
Clint40's Avatar
Clint40
Are the mono tube shocks rust resistant also?? And the 200.00 mentioned is that a set or two and where to order tham, at the best price would be appreciated, I need shock too. But my 250 has NO lift and if I do I will only go up to 3 inches or so.
Old Oct 11, 2007 | 12:33 PM
anotherfordguy
Its about 200 each for the reservoir shocks. the mono tube shocks run around 100. Both have the same coatings. The shocks are made for 3"-6" of lift and 8"-12" of lift so if you get the leveling kit you can use them.
