winter oil
Old Oct 6, 2007 | 10:45 AM
Cuda_jim's Avatar
Cuda_jim
Either one will be OK. It's personal preference IMO. The 5 means the oil acts like 5 weight oil when cold so both will help with cold weather starting. I llike the 5w40. Just
Be sure it's diesel rated oil.
Old Oct 6, 2007 | 11:27 AM
MLCinNCTX's Avatar
MLCinNCTX
Originally Posted by barebackjake
migrate to tx for the winter!! enjoy the chilly 50deg days we could use some more good shoer's down here
That is what I was thinking, move here and just stay home the 2-3 days of winter. Don't want to hear about the heat. Remember you don't have to shovel hot!
Old Oct 6, 2007 | 11:39 AM
wycowboy's Avatar
wycowboy
Tenping jake but I love the mountains.
any thoughts on change intervals / 10K?? what about running a bypass filter?
Old Oct 6, 2007 | 04:13 PM
barebackjake's Avatar
barebackjake
we have hills!!
ive got like 30k on the oil with bypass, i think amsoil says 10k w/o bypass im changing filters and having it tested every 10k
Old Oct 6, 2007 | 07:59 PM
wycowboy's Avatar
wycowboy
so I've been shopping around. and it seems that is I'm going to switch to syn. I should also put in a bypass filter while I'm at it..I've been thinking of going with the Amsoil filter and there 5w-40oil anyone heard any theing bad about this set up? any other recomendations ? I looked at the oil gaurd but it is slightly more exspensive and since I was thinking of going amsoil the whole way I thought I would use theirs. thanks for any thoughts J
Old Oct 6, 2007 | 08:48 PM
MADVAN's Avatar
MADVAN
Go with a bypass system. All are good. Your oil will be cleaner and last longer.
You will not regret the change this winter.
I have noticed that the winter startup is better with the 5/30 than 5/40.
As the oil is used and ages it beats itself thick. In other words a 30 can become a 40.
On a note the 40wt nets a very slight advantage in mpg.
Bill
Old Oct 6, 2007 | 10:16 PM
wycowboy's Avatar
wycowboy
Thanks for all the good info bill. why dose the 40wt get better MPG? I would think that the lighter 30 wt would. what buy pass sys do you run? J
Old Oct 6, 2007 | 11:35 PM
MADVAN's Avatar
MADVAN
Yep. Normally the 30wt would do better windage wise in the crankcase ect. The PSD also uses the oil to drive the injection system. A scanner has shown that the 40wt makes a slight bit more pressure across the RPM band than the 30wt. The higher pressure helps with timing and atomization of the fuel.
I use the amsoil bypass. (stand alone unit).
Dont like to name brands anymore when all are good. To many BS oil wars.
Bill
Old Oct 7, 2007 | 09:17 AM
c00nhunterjoe's Avatar
c00nhunterjoe
oil does start wars, so here is mine, i run 15\40 std oil year round, with 230k i am not going to run a thinner oil in her. if it gets to cold out i plug it in, thats the reason for the heater......lol also if its that cold out i emjoy firing the truck up and turning the heater on to have hot air blast me in the face
Old Oct 7, 2007 | 10:54 AM
wycowboy's Avatar
wycowboy
thanks every one for all the good advice.. keep it rollingJ
Old Oct 7, 2007 | 12:03 PM
MADVAN's Avatar
MADVAN
230K!
We have an over the road car carrier here. Its has a little over 1 million on it
(*** 14). Motor has never been opened. Runs great. Has had 5/30 oil in it for 90% of its life.
Bill
LoveDDs
Nov 2, 2012 06:16 PM
whitesdford
Oct 27, 2011 09:44 PM
zachsherman88
Feb 22, 2009 02:40 PM
oldgameandfishdiesel
18
Nov 16, 2008 06:44 PM
hancockr
1983 - 2012 Ranger & B-Series
Sep 14, 2006 01:21 PM
