what is this light
Old Oct 3, 2007 | 07:51 PM
JICASE's Avatar
JICASE
what is this light
While driving down the road this afternoon a light illuminated in my truck that I am not sure what it is. The truck is a 2003 f-350 cc, 4wd, 7.3 powerstroke auto. The light is in the left corner of the dash and it looks like a water valve. My coolant level is in the normal range on the reservoir. What else could it be? It out about 10 minutes later.
Old Oct 3, 2007 | 08:22 PM
JIM ROLAND's Avatar
JIM ROLAND
My 2000,7.3 has a light that will read "water in fuel" if indeed that is the problem. I am not familiar with your year model's lights but you might drain your water fuel separator, (the yellow valve to turn is right behind the fuel filter bowl. Hope this helps. Someone with your year model may chime in on this.
Old Oct 3, 2007 | 08:25 PM
dieseloholic's Avatar
dieseloholic
I agree; water in fuel light. Don't you have the owners manual. It would list all lights, locations and what they mean.
Old Oct 3, 2007 | 08:42 PM
powerstroke6ltr's Avatar
powerstroke6ltr
From top left to bottom left, my annunciators are:
water in fuel (looks like rain drops towards a fuel pump)
wait to start (looks like a curly wire)
Low fuel
check engine (looks like motor)
and fasten seat belt
Old Oct 3, 2007 | 09:16 PM
JICASE's Avatar
JICASE
You are right it is the check engine light. I was not looking at it the right way. Why is it coming on and then going off. I do not have a chip or a scanner is there anyway to see if it is storing any codes?
Old Oct 3, 2007 | 09:38 PM
clintbonnie's Avatar
clintbonnie
Get someone to read your fault codes.. You must use a scanner that is for powerstrokes. If your engine light came on, it will store a code.
Old Oct 3, 2007 | 10:01 PM
spinge's Avatar
spinge
Don't do the AutoZone (or other parts store) route, as they normally CAN'T read Powerstroke codes.
Old Oct 3, 2007 | 10:05 PM
powerstroke6ltr
Can't you use the cluster as a diagnostic reader?? Mine was displaying codes earlier...
Frankiec#1
Feb 15, 2021 09:47 AM
2006 F-150 FordSter
2004 - 2008 F150
Jun 29, 2012 08:49 AM
carolinaborn82
2004 - 2008 F150
Jun 25, 2012 11:17 PM
nightowl263
Dec 20, 2011 10:45 PM
yoeman
Nov 11, 2006 11:42 AM
