glow plug controller
Old Dec 5, 2007 | 07:06 PM
  #31
Dave Sponaugle's Avatar
Dave Sponaugle
You are running power to the terminal the small yellow wire is on from your push button?
If that is the way you have it wired, your switch and the wire you are using have to handle 200 amps to heat the glow plugs.
A ground applied to the white wire terminal closes the relay when the key is in the ON position.
So the relay and stock wiring is carrying the big amp load.
luvemhot
Oct 23, 2012 10:12 AM
mlouritt
Aug 15, 2011 03:01 PM
tpolley
32
Dec 9, 2009 09:47 PM
66f100prostreet
Nov 14, 2009 09:35 PM
Thunderbox
Oct 26, 2004 09:00 PM
