Engine oil temp -- HIGH???
Old Sep 28, 2007 | 02:28 PM
johnsjsj's Avatar
johnsjsj
Finally got around to putting in even some more gauges from Diesel Manor. Put in a Water Temp, Volt, Engine oil temp.(alredy got the other in). Put the sensor in to the port on the filter housing as suggest by people on here.Took it out for a drive. At highway speed (60--65) with no load, cruise control set. outside temp. was 70. Temp got up to 205 to 210 degrees and did not come down to only 200 degrees at idle after 10 minutes. My question is: Is this the normal temp.? It seems rather high to me. I am worried about towing my 5th wheel in hot weather if this temp. is already high. What is everyone else running? Is there a better place to get a reading?
Thanks for the help
Old Sep 28, 2007 | 02:44 PM
Kwikkordead's Avatar
Kwikkordead
That temperature is exactly what you want to have.
Cold engine oil gets dirty a lot faster than oil that is just under the boiling point of water.
Hot oil boils off any condensation, etc and stays cleaner for a longer period of time.
Old Sep 28, 2007 | 09:09 PM
johnsjsj's Avatar
johnsjsj
Doesn't that seem high for no load. In the summer heat with the 11000 lb. 5th wheel being pulled through the mountains, it seems that temp could get pretty high. Anybody else had some temp readings while pulling?
Thanks
Old Sep 28, 2007 | 09:50 PM
tholt34's Avatar
tholt34
when towing my edge evo II says my oil temps stay aroudn 220 most the time. don't ever really get any hotter that. I have heard that around that range is where is good to run.
Old Sep 28, 2007 | 11:40 PM
kupaa's Avatar
kupaa
Here in Hawaii,my average temp is 185-200.Do a search on eot because i had the same question.
Old Sep 29, 2007 | 05:54 AM
ron's power stroke's Avatar
ron's power stroke
depends alot on what thermostat your running (195* or the 203* thermostat) as well..200 to 205 is a good #
Old Sep 29, 2007 | 08:51 AM
FN74's Avatar
FN74
Same here, I see 200-205 most all the time. Under load it gets up to 220-225. No worries
Old Sep 29, 2007 | 10:52 AM
powerstrokinsmokin's Avatar
powerstrokinsmokin
Welll i work at a Mack Volvo truck dealer ship as the shop foreman. We see oil temps 230-245 F all the time. The oil today can with stand so much more heat with out break down. I run 200-210 most of the time climbs to 225 when towing. Took an oil sample with 180,000 miles. no major issues with the oil. Had 6500 miles on oil changes.
Old Sep 29, 2007 | 11:47 PM
jtharvey's Avatar
jtharvey
My temp sensor is in the HPOP res, and I see 240 every time I'm on the highway. Never goes any higher than that though. I do have a 203* thermostat.
DawnPatrol
Jul 9, 2016 09:12 PM
wracefans24
2004 - 2008 F150
Jun 23, 2015 01:47 AM
wracefans24
2004 - 2008 F150
Jun 15, 2015 01:37 PM
mgood
Feb 28, 2012 05:28 PM
