Window Crank Handle
Old Sep 27, 2007 | 07:28 PM
seven up's Avatar
seven up
Window Crank Handle
Hi All.
What are the procedures for removing the window crank handle. It's a 70 F250 Regular Cab. The thing will not budge and I don't wanna ruin the door panels. Thanks.
Doug
Old Sep 27, 2007 | 09:27 PM
Customcab's Avatar
Customcab
I don't think there's an easy way to spray some type of break-free on the handle regulator crank; I can only suggest to turn the screw as if tightening and maybe it will break free and allow you to unscrew the screw. That's a hard question to answer.
Mitch
Old Sep 27, 2007 | 10:31 PM
Mil1ion's Avatar
Mil1ion
JUst a thought.
is there a screw through the center of the window crank attaching it to the window regulator
or
does that era have the horseshoe clip on the back that requires a special tool ?
Do you have a pic ?
Old Sep 28, 2007 | 12:00 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
The handle is held on by a allen screw, remove it handle falls in hand.
Old Sep 28, 2007 | 01:27 AM
seven up's Avatar
seven up
No screw or clip. The face of the handle is solid with no removable cap. Just thought there was some special trick to it. There's a couple of pictures of the mess in my gallery.
Thanks.
Old Sep 28, 2007 | 09:28 AM
Unimog005's Avatar
Unimog005
I could have been glued on by a previous owner...in which case, you may have to disassemble the entire door panel to get it apart....go ahead and look up the parts, something is likely to break in the process.
Old Sep 28, 2007 | 10:23 AM
"Beemer Nut"
Looks like you have a thin aluminum stick on disk that covers the allen bolt.
With a thin knife blade you should be able to get under it and lift it out.
Old Sep 28, 2007 | 08:25 PM
Mil1ion's Avatar
Mil1ion
Beemers correct.
Take a pen knife and carefully pry up on the edge of the center disc.
don't let the sticky back touch anything while you work on the handle.
Old Sep 29, 2007 | 03:24 PM
seven up's Avatar
seven up
For cryin out loud. I think I need lazic, whatever. A little foil cap over the screw.
Thanks for helping me with this. I've learned about many parts to do with the door.
You've saved my door panel !
Doug
Old Feb 7, 2015 | 05:04 AM
mountndreamer's Avatar
mountndreamer
The crank for the window is usually a t20 screw under the cover. There is a notch to get a flathead or body pick in to lift it so you can turn the plastic cover out of the way. That slot is at the bottom end,the same end the bolt will be in.
Old Feb 7, 2015 | 05:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
That slot is at the bottom end, the same end the bolt will be in.
1968/72 F100/750 & 1969/74 Econoline window crank handle is retained to the stud of the window regulator by: 381571-S13 .. #8 -32 x 5/8" Oval Head Screw.
sweet55
20
Jan 10, 2018 10:32 PM
darmento
Aug 2, 2016 03:07 PM
thomasstemmle
WTB - Parts & other
Aug 1, 2016 03:38 PM
MIKES 68 F100
18
Jun 3, 2016 06:49 PM
65f100Pit
Sep 7, 2015 01:01 AM
