Sponsored by: Real Truck
Trans fluid change question
Old Sep 27, 2007 | 03:26 PM
SuperDuty5.4Guy's Avatar
SuperDuty5.4Guy
I just changed my trans fluid today, not a full flush but just removing the pan and changing the filter. The kit I bought had a new rubber pan gasket and filter in it. The 'directions' say not to use the gasket in the kit if the pan has a reusable gasket. Well, not knowing this before, I put the gasket on that was in the kit. My question is, will the new gasket pose a problem or should I just leave it on and keep the factory reusable gasket as a spare? Also, on the new gasket, I did not put any sealer on because the factory gasket did not have any.
Old Sep 27, 2007 | 03:44 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You should be good till it leaks. Just keep an eye on it for leaks.
Old Sep 27, 2007 | 05:56 PM
NORTHLAND06's Avatar
NORTHLAND06
Talking
The reusable gkst is was should have put back on tran. their is reason for that gkst being on there in first place and it more and liklly would not leak as easy too.
triskadek
Jun 15, 2020 04:51 AM
minnesotafisherman
Sep 22, 2012 11:44 PM
powerstroker100
46
Jun 7, 2010 02:19 AM
kjf-250
2004 - 2008 F150
May 26, 2010 09:19 PM
ntstock93
1997 - 2003 F150
18
Mar 27, 2010 11:31 AM
