Sponsored by: Auxito
Trans Fluid Change
Old Mar 20, 2010 | 07:05 AM
ntstock93's Avatar
ntstock93
Trans Fluid Change
I'm getting ready to change the tranny fluid in the truck.
I read on the pan that the gasket is reusable. Is this true or should I just get a new one.
Whats the better trans fluid and which type?
How many quarts am I looking at by changing pan fluid and the tourqe converter fluid?
1998 f150 2wd 4.6ltr
Old Mar 20, 2010 | 09:35 AM
ntstock93's Avatar
ntstock93
Ok. I did a search and found that draining the TC and Trans pan is 13 quarts of fluid. How much more than the 13 does the trans hold?
Gasket reuseable?
Old Mar 20, 2010 | 09:59 AM
Ron W.'s Avatar
Ron W.
I could be wrong but I don't think there's a drain plug in your converter, so all you're going to get is the fluid in the pan.
If the gasket is factory or has been replaced with a OEM or equivalent, yes it should be reusable. It's stamped steel with with a bead of attached rubber on both sides, be careful while taking the pan down so you don't cut into the rubber.
Old Mar 20, 2010 | 03:29 PM
steve(ill)'s Avatar
steve(ill)
trans holds 5 quarts, converter holds 8. 13 total..... i think the converters prior to 2001 have drain plugs. my 2001 has one and it was one of the last.
Old Mar 21, 2010 | 07:17 AM
ntstock93's Avatar
ntstock93
Ok. Great.
Old Mar 21, 2010 | 08:30 AM
Joe Finn's Avatar
Joe Finn
My '97 has a drain plug too.
Old Mar 22, 2010 | 11:45 AM
ntstock93's Avatar
ntstock93
Did the fluid change today. Did pan and TC drain. 3 gallons of fresh trans fluid and that is one happy transmission. No more shudder and shifts smoother.
BTW what is the correct torque for the trans pan bolts?
Old Mar 22, 2010 | 05:52 PM
steve(ill)'s Avatar
steve(ill)
hope you didnt get that pretty red dress all oily !! LOL
Old Mar 22, 2010 | 06:25 PM
redwood's Avatar
redwood
Old Mar 23, 2010 | 09:38 AM
stvMo1's Avatar
stvMo1
In my 2003 ,if the converter has no plug,how do you get the old fluid out ??
thnx
Old Mar 23, 2010 | 09:40 AM
ntstock93's Avatar
ntstock93
Yeah. Funny.
Here is link-
SPORTSbyBROOKS Girls
Old Mar 23, 2010 | 08:38 PM
steve(ill)'s Avatar
steve(ill)
my 2002 EXP has no converter drain. I just do the 5 quarts in the pan, bu tdo it every 60k miles. If you want to change the oil in the converter, you will need to take off one of the transmission lines to the radiator cooler and pump it out, or drain all you can.. Then you put 7-8 quarts in the trans and start motor for a few minutes, then add 2-3 morre quarts and run again, then fill as needed to full.
Old Mar 24, 2010 | 08:32 AM
stvMo1's Avatar
stvMo1
I think I'll take off the cooler line and get it all out..
thnx
Old Mar 24, 2010 | 10:07 AM
Lennyg's Avatar
Lennyg
I've been studying how to replace my ATF as well. Disconnecting lines looks like quite a job on my 2001 XL 4.2 with 4R70W. Nearly impossible at the transmission (lines are one above the other) and difficult at the radiator (especially the lower one).
Would it damage the transmission if I:
drained the pan and converter,
then temporarily reinstalled the pan and converter plug,
then ran the motor for a few seconds to pump the remaining fluid through the cooler and into the pan,
then drain the pan and converter again?
Old Mar 25, 2010 | 06:20 PM
green 1969 f100's Avatar
green 1969 f100
Why not take it to a reputable repair shop and have a complete fluid exchange?
