transmission pan gasket
So I had what was probably the original factory reusable gasket, and the pan is stamped that it comes equipped with such. After the big tow moving across the country I bought a filter kit and proceeded to change the filter and fluid. The kit came with a rubber gasket and I thought "oh isn't that fancy, the last one I got didn't come with one". Well, I was less than careful about getting the pan down and did nick the reusable gasket. I went ahead and slapped on the new one after taking forever to clean the old one off. Now, a couple days later, I was cleaning up in the shop, and there in the bottom of the kit was a little slip of paper stating that I had better not ever use the rubber gasket that came with the kit if my truck was equipped with the reusable gasket! and that I better get in touch with the manufacturer to get the right one. It seems fine...but I haven't put it under any tremendous load. It didn't seem like it was too big and going to leave excess on the inside once I torqued it down. It doesn't leak. Not sure why it could possibly pose a risk, but thought I would ask if anyone had any ideas of why this could fail.
The gaskets in the kit are notorious for leaking. That's the only reason they say to use the factory reusable if it has one. I silicone the **** out of the throw-a-way ones if I have to use them. Its not going to cause any catastrophic failure or anything though. Just may or may not start seeping a bit
Corpsman24
08-19-2013 10:18 AM
paulghenderson
08-14-2003 08:36 AM
