I'm pretty sure my AC needs to be charged. Does one of those do-it-yourself kits from the auto parts store really work? Has anyone done it with success, or should I spend the money and get it done professionally?
Many have done it themselves but, those that do it on a regular basis stress the importance of a good set of gauges and making sure the system is properly charged. Do you really want to risk your $1500 AC system on a cheap kit?
If your going to do it yourself defintely buy a good kit. Being that freon never goes bad you must have a leak somewhere. You can buy a can of stop leak to add to the A/C system, I have used it and it works well. I would definately get the leak found and repaired before charging.
Not sure if it has leak or not,,its just not as cold as it used to be and if Im driving slow or stopped in traffic it dont blow that cold at all..Just figured it needed to be charged.
Probably not. Low refrigerant usually manifests as compressor short-cycling.
I'd be looking at the system pressures and at your fan clutch as being weak.
Steve
I actually have the same problem, my freon level is full, but the a/c is not as cold as it used be. Can you explain in a little more detail, how to check the system pressure? and how to determine if the fan clutch is weak?
Attach the manifold gauge set to the high and low side ports and start the system.
Run the engine at 1500 RPMs, then hit the center of the condenser with the spray from a garden hose while watching the high side pressure. If it was too high before then drops below normal with the cool water, the clutch is probably weak and isn't pulling enough airflow through the system. While you're at it, clean the condenser and radiator with the hose since dirt, bugs, etc can restrict the airflow and cause the same symptom (diminished cooling, elevated high side pressure).
Several of the guys around here suggest to replace the fan clutch anyway if it's over 6-7 years old.
look at a community college for a course on Auto AC...
this will teach you everything you need to know...
and you'll get to use the schools equipment to test/diagnose and fix your
problems...
in lieu of that.. try getting a good book on automotive AC from amazon.com
in lieu of that... buy a AC manifold and guage set from a place online like www.thetoolwarehouse.net ...
connect to the high side /and low side of your compressor... (or your fittings wherever they are)... then look at the pressure of both with the system running vs. the outside temperature....
If you system is low it obviously leaked out somewhere, this is bad...
you'll need vacuum pump and a leak detector to find out exactly where it leaked out..
this is where things start to get expensive...
My opinion is ...get educated first... acquire as much knowledge as you can via
school or online or books ...then go from there...
I figured out AC work myself last summer with my Explorer. I picked up a vacuum pump and a set of gauges. Between those and scouring the internet, I was able to figure it out. It really is not that hard. Do a lot of reading online and then accept the fact that you will end up wasting a few cans of R134a learning stuff.
you get a set of gauges and connect to the low pressure side and the high pressues side. run truck at 1500 RPM. the pressure should be aboug 35 psi and 200 psi. if it is 25 psi and 150 psi you need freon. if it is 35 psi and 300 psi, you have a plugged radiator and getting no air flow for cooling, etc.
