Have a 2001 f150 v6 auto. she will not start while in park. have to change to N to start. also when i place in park from any gear park will not engage will just start to roll for a couple of feet then engage. any thoughts and help will be appreciated.
linkage is not adjusted, or lock inside the trans pan is not set right. should lock into park and engage the electric switch to allow start. neither is happening.
