Request and a statement...
Old Sep 27, 2007 | 07:07 AM
  #31
Forge's Avatar
Forge
Okay, so... what do I need to do to fix this?
Here are my ideas...
1. Push hose on ALL the way.
2. Check bed/tank mounts and angles.
3. Get upset.
4. Cut hose.
Old Sep 27, 2007 | 07:38 AM
  #32
m78's Avatar
m78
Forge I can send you pics if I had an email address . I dont have much luck with them here. I'm leaving at 9AM EST
Old Sep 27, 2007 | 12:02 PM
  #33
Forge's Avatar
Forge
subversion992003@yahoo.com
Old Sep 27, 2007 | 05:36 PM
  #34
just-n-time's Avatar
just-n-time
Thumbs up Lets get it wright
Originally Posted by Forge
Ok... so...
1. Try to shorten pipe.
2. If shortening fails, install connector...?
I get it right?
If the hose from the filler connection to the tank is to long,first look to see if you can move the tank in its brackets,to the right as much as you can.
When this fails,and you are sure you have the connections seated all the way, then the only other option is to lift the bed to complete the connection,or possibly cut the fill pipe to shorten it to the length needed.BUT when you do that you will need to make a but connector to seal of the fill pipe and make it back into a one piece pipe.JNT
Old Sep 28, 2007 | 06:39 AM
  #35
Forge's Avatar
Forge
Found out three things...
1. Aamco busted a hole in the METAL filler tube.
2. The vent hose is heavily dry rotted.
3. Aamco only changed HALF the vent hose, and did not push the hose on all the way, nor tightened the hose clamp down.
RM2738
6.7L Power Stroke Diesel
May 7, 2012 07:52 AM
sc0r1a
Oct 10, 2011 10:25 AM
rjmay
Mar 10, 2009 07:40 PM
parks911
General Automotive Discussion
26
Oct 12, 2004 09:28 PM
