Sponsored by: Real Truck
Any truth to this
Old Oct 9, 2011 | 09:58 PM
sc0r1a's Avatar
sc0r1a
Any truth to this
Here is my situation, I got a 2001 f250 back in June and the transmission was slipping when I got it, reverse being the real problem when your on a slight incline you almost had to give it full throttle to go anywhere. WELL I just got the tranny rebuilt this week, its been in the truck for about 4 days, and reverse still seemed soft at first and I started noticing it slipping more and more. I asked the guy who rebuilt it (certified mechanic) whats going on. and he said the computer has to "re-learn" and to watch it another week or so to see what it does. Well today it started slipping even worse, almost as if reverse wasn't there.
My question: is there any truth to the statement "the computer has to re-learn how to shift" I've heard conflicting arguments of his statement being true and the other being complete BS
I'm starting to get really PO'd with the truck and need to know if he's BS'ing me and i need to raise hell or if he's telling the truth and relax a minute.
Old Oct 9, 2011 | 10:02 PM
barthel's Avatar
barthel
Yes, the computer does have to relearn it shift strategies, but that's only if it's been reprogrammed or if the battery has been disconnected.
Seems to me if it's still doing the same thing, maybe the trans wasn't the problem to begin with, or it wasn't actually rebuilt.
Old Oct 9, 2011 | 10:11 PM
sc0r1a's Avatar
sc0r1a
The guys are trust worthy, so I do believe that it was rebuilt.
If I disconnect the battery that should restart the computer and help the shifting?
Where should I start looking if it isn't the tranny? Does the G.E.M. module have anything to do with the shifting?
Old Oct 9, 2011 | 10:12 PM
jascott1988's Avatar
jascott1988
If it was a newer truck I would say its possible, but being an '01 I really doubt it. I'm a "certified mechanic" as well, but that's in electrical and a/c on medium/heavy duty trucks, not TRANSMISSIONS. Always find out what the mechanic is certified in.
Old Oct 9, 2011 | 10:25 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I think the 4R100 learns some basic things. The 5R100 does learn quite a bit.
Old Oct 9, 2011 | 10:41 PM
kd0axs's Avatar
kd0axs
Yes, the computer needs to relearn your driving habits, but it shouldn't slip like that. Hopefully the guy guarantees his work, because it sounds to me like there is still something wrong with the transmission.
Old Oct 10, 2011 | 01:17 AM
Daz00Excursion's Avatar
Daz00Excursion
My Backpack Gots Jets
double check trans fluid?
Old Oct 10, 2011 | 01:24 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
"Oh. No I didnt refill your ATF after servicing the transmission. I thought you were going to do that when you got home"
Old Oct 10, 2011 | 01:26 AM
CHELLIE's Avatar
CHELLIE
On newer vehicles, if you have a trans problem, take it to the dealer, yes it will cost a tad more, but your covered, and the dealer will normally install a ford factory reman trans with all the up dates, Just my 2 cents worth, Take care and have fun, Chellie
Old Oct 10, 2011 | 01:31 AM
Daz00Excursion
hey it happened to me! lol.....picked up my my truck from the trans shop (reworked 4l80E for my LQ9 swapped 00 silverado) went to back out of parking spot...it barely moved. after going over everything including hooking the computer found out low line pressure. after scratching our heads..figured i would check the fluid. low and behold, it was few quarts low. i learned my lesson not to take to a repair shop where beer cans was stacked to look like a sofa in the corner garage
Old Oct 10, 2011 | 05:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's absolutely false. The computer in a 2001 does not learn anything at all about shifting. Disconnecting or reprogramming does not cause the computer to have to learn. It's incapable of learning.
No Ford computer learns driving habits.
Later models DO learn, but not 2001, and not driving habits. What they do learn is how long a shift takes from when the computer commands it until the shift has completed. Then it can adjust the shift pressure for next time it makes that shift. But again, the 2001 computer was not capable of doing that.
Old Oct 10, 2011 | 07:03 AM
hanklin's Avatar
hanklin
Did you check and see if any codes are being thrown? It may be the pcm is bad. I think mine costs about $300.00
Old Oct 10, 2011 | 07:05 AM
hotroddsl's Avatar
hotroddsl
Not the PCM that's bad it's the rebuilt 4R100 that's bad!
Jim& fat Monty
Old Oct 10, 2011 | 07:07 AM
hanklin's Avatar
hanklin
how do you know this Jim? I said Maybe, what would it hurt to pull codes.
Old Oct 10, 2011 | 07:14 AM
kd0axs's Avatar
kd0axs
Not saying you are wrong, but that completely contradicts everything I've ever been told, even by ASE certified technicians.
However, I can't say that I have ever noticed any difference after disconnecting the battery on any vehicle I've ever owned.
