Request and a statement...
Old Sep 25, 2007 | 09:19 AM
m78's Avatar
m78
did yours come with the wide metal U shaped plate?
Old Sep 25, 2007 | 10:43 AM
Forge's Avatar
Forge
Yes, does we haven't gotten that far yet. It kinks before we can even tighten things down.
Old Sep 25, 2007 | 11:25 AM
m78's Avatar
m78
Maybe your fill hose is not ridgid enough. where did you get it. theres also room for play if you shortened it.where is it kinking? also the hose for the rear hardly has a bend in it, did the give you the correct one?
Old Sep 25, 2007 | 12:07 PM
Forge's Avatar
Forge
The factory one kinked shortly after they put a new tank in. It's kinking just outside of the bends on each end.
Old Sep 25, 2007 | 12:21 PM
oem78's Avatar
oem78
Maybe pressure in the tank is causing the kink, check the vents and gas cap.
Old Sep 25, 2007 | 12:45 PM
Forge's Avatar
Forge
The hose was slipped on and it kinked. We did not crank the truck, tighten the gas cap down, and the vents were cleared.
Old Sep 25, 2007 | 01:35 PM
just-n-time's Avatar
just-n-time
So if I am correct in what you describe,it sounds like the filler pipe is to long and the pressure from forcing the pipe into that distance is causing the pipe to fold up (kink). Can you cut it in the straight section and shorten it? you may have to build an aluminum connector and clamp it. JNT
Old Sep 25, 2007 | 03:19 PM
Forge's Avatar
Forge
Ok... so...
1. Try to shorten pipe.
2. If shortening fails, install connector...?
I get it right?
Old Sep 25, 2007 | 04:38 PM
m78's Avatar
m78
I just did mine last month and didnt have any of these problems,But I didnt put a different tank in. Do you know if they used the correct tank?
Old Sep 26, 2007 | 06:37 AM
Forge's Avatar
Forge
They used a polymer tank. I have a feeling noone's pushing the hose on hard enough.
Old Sep 26, 2007 | 11:50 AM
Mil1ion's Avatar
Mil1ion
You mean "Peter Noone" of Herman's Hermit's ?
( No one... is 2 words)
Perhaps the fuel hose you have is of a different material that is prone to easier collapsing?
Old Sep 26, 2007 | 12:35 PM
Forge's Avatar
Forge
But why would the factory hose do the exact same thing, in the exact same spots. The one I bought was from Dennis Carpenter.
Old Sep 26, 2007 | 12:45 PM
  #28
Mil1ion's Avatar
Mil1ion
Has the bed settled ?
This is usually the reason for kinked hoses.
Old Sep 26, 2007 | 01:49 PM
  #29
Forge's Avatar
Forge
Don't know. There're no tool marks on the bed bolts...
There appear to be marks on the gas strap bolts...
from when they changed the tank...
(P.s. Nonne, ain't two ah werd.)
Old Sep 26, 2007 | 03:52 PM
  #30
Mil1ion's Avatar
Mil1ion
Nonne is one word (if it is actually a word) .....but Yes "No One" is 2 words.
*chain yanked*
Nyuk Nyuk !
The bed can just fall or Sag/Settle from being old.
Check all the bed mounts.
