Sponsored by: Auxito
Head Gasket
Old Sep 19, 2007 | 02:30 PM
Black97F150v6's Avatar
Black97F150v6
Head Gasket
Well, it seems to me that I now need a new Head Gasket....anyone have an estiamte about how much it should cost me while it is all said and done?
Old Sep 19, 2007 | 03:29 PM
vanman250's Avatar
vanman250
Why do you think you need a head gasket?
vanman250
Old Sep 19, 2007 | 04:20 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Question
vanman250
Yeah,who determined you need a new head gasket? And,how did they come to this conclusion?
Old Sep 19, 2007 | 10:21 PM
Black97F150v6
Well, from what i hear, the condensation underneath my oil cap is apparently the result of a busted gastket...I have no idea...I am running out of hope for this truck
Old Sep 19, 2007 | 11:09 PM
duggyb's Avatar
duggyb
is it white residue on your cap?
if so clean the cap...and take your truck for a 5-10 minute drive....check cap....residue should be there.......now wipe again and take it for about a 30 min drive....and drive it hard!!......then check cap....whats the result?...if its a clean cap...you got nothing to worry about!
the reason the residue forms is becuase the filler neck is so far up from the valve cover...and in short drives condensation forms.
THNX
Duggy
Old Sep 19, 2007 | 11:11 PM
LxMan1's Avatar
LxMan1
That is usually a sign of short trips not letting the oil heat up enough to burn of any condensation and or a bad PCV valve not evecuating the system properly. If there is no sign of milky residue on the dipstick, then you just need to take it on a long drive to get things good and hot inside the engine.
Black97F150v6
I am afraid to run it hard...the noises are extreme...scare the hell outta me
Old Sep 20, 2007 | 04:21 AM
BlueOvalFitter
Exclamation
As I stated in another post I think your bearings are bad from coolant leaking into the oil!
Get a UOA to determine this! They only cost $15-$20! Call your local Caterpillar dealer or any tractor company! Look under "Lubricants" in the yellow pages!
Old Sep 20, 2007 | 09:26 AM
Black97F150v6
Would it make my 6 cylinder sound like a diesel?
Old Sep 20, 2007 | 05:03 PM
BlueOvalFitter
Exclamation
If its detonation then yes,it will sound like a diesel.The 4.2V6 is known for carbon build up and bad detonation from it.But,if your bearings are bad then you could hear a slight knocking,which could also sound like a diesel,in a way.
Are you having to add coolant or is the tank low?
1972RedNeck
13
Dec 5, 2011 04:55 PM
jake47
1983 - 2012 Ranger & B-Series
Dec 1, 2006 06:48 AM
lifted77f250
Jun 8, 2006 02:57 PM
gollygwagen
Oct 4, 2005 01:23 PM
bigsnag
Aug 9, 2000 07:44 PM
