Bad head gasket?
Old Jul 15, 2000 | 07:19 PM
bigsnag's Avatar
bigsnag
Bad head gasket?
Old Aug 8, 2000 | 11:22 PM
mac67's Avatar
mac67
Bad head gasket?
Help!!! I have a '89 F-150 w. 5.0L engine. When engine is cold, no problem, however, when engine warms up there is coolant getting into the exhaust(steam visible from tail-pipe and loss of power). There is no coolant in the oil, no oil in the coolant, and engine doesn't "miss" when idling. No visible leaks, etc. Compression is in range for an engine w. 120k miles. Plugs don't seem to be fouled/wet. I think head gasket, but mechanic doubts since compression is acceptable. Any ideas on what it could be? Intake manifold gasket? I'd like to have a better idea before I tear it apart!
Old Aug 9, 2000 | 07:44 PM
donsboy's Avatar
donsboy
Bad head gasket?
you may have a bad head gasket but i cant see how you would get water in the exhaust. you may have a cracked head thats seeping water into the port from the water passage.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
