fuel filter
Old Sep 18, 2007 | 06:49 PM
bluthunder's Avatar
bluthunder
fuel filter
is there a filter to replace the factory filter? thr drain is worn out on mine and leaks. i think i have seen filters with the drain built into the bottom, not a separate unit like the origional.
Old Sep 18, 2007 | 07:08 PM
Don Senkow's Avatar
Don Senkow
You might want to try a Wix 33417. What you have now is a 33217. The difference is no water in fuel sensor. It does have a drain. The Wix website has pictures. I'm sure the Wix numbers will cross to whatever you prefer. Don
Old Sep 18, 2007 | 07:40 PM
brownieboy525's Avatar
brownieboy525
you can get them at napa they are a one pice unit the does not use the bottom of stock filter
Old Sep 19, 2007 | 06:06 AM
fonefiddy's Avatar
fonefiddy
Also, the Wix 33617 has provisions for water sensor
Old Sep 19, 2007 | 03:12 PM
Don Senkow's Avatar
Don Senkow
NAPA filters are Wix, They drop the 3 in front from the P/N. Don
Old Sep 22, 2007 | 07:22 AM
bluthunder's Avatar
bluthunder
sorry it took so long to respond. dial-up connection is terrible here. thanks for the info.
macguy
6.7L Power Stroke Diesel
Dec 3, 2012 07:17 PM
macguy
16
Oct 23, 2012 07:58 AM
justin1795
Jan 30, 2012 03:34 PM
kjstephe
Dec 18, 2009 08:34 AM
bob 2008 F250
Jul 30, 2009 12:25 PM
